Question about Refrigerators
Kenmore side by side. No water getting to the ice maker. Water in the door works fine. Have already replaced the filter.
  • 4,066 Answers
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Sep 14, 2010
I have a Kenmore Coldspot Side by side refrigerator model 58787892. The ice maker is not making ice. The mechanics of the maker work but it does not fill up with water. The filter is changed regularly...
check to see if the ice tube going into the ice maker is frozen up. you may have to thaw it out to get water to reach the ice maker again. lmk if that's not it
Aug 05, 2013 | Refrigerators
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
May 29, 2009 | Kenmore 44103 Side by Side Refrigerator
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
No water but ice is fine
remove the filter and reinstall , it may not have seated into the filter housing it will take a little while to fill the filter cartridge as you hold in the water paddle
you also may have a water valve problem, something in the water valve that goes to the water in the door that is not allowing the water to come through the valve
Apr 24, 2008 | Refrigerators
Ice and Water Dispenser not responding...
had the same problem, there was a component in the front user panel that was shot
Mar 29, 2008 | Kenmore 44103 Side by Side Refrigerator
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
No ice...different question
Are you able to see if you can push a Q-tip or something up the fill tube line to see if it's frozen up inside there. It happens on certain units. You may need to take the Ice Maker out (easy) to get to the fill tube.
Feb 27, 2007 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
