Question about GE Spacemaker JVM1640SJ Microwave Oven
I've got the same problem. Any ideas? - GE Spacemaker JVM1640SJ Microwave Oven
  • GE Master
  • 43,501 Answers
I am not sure what your problem is but I can give you a tip that I wrote that covers most all of the problems you might encounter with a microwave...
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 14, 2010
My Panasonic Dimension 4 microwave/convection oven (NE9870) is dead. It was running, produced a small popping sound and is now completely dark. I've tried alternate electrical outlets and there...
Ken,
Usually there is an internal fuse and that is probably your problem. You will need to take off the outside cover of your microwave and then look where the power cord goes into the back of the unit. Look for the black wire coming out of the power cord and follow it. It should take you to the fuse. Hope this helps!
Dec 16, 2014 | Panasonic NN-T888S Convection/Microwave...
JVM1740DM1WW
There are three microswitches. All are interchangeable.
This will give you the idea.
V3 Microswitch SPDT 16A Micro Switch eBay
Match the type of actuator and order a couple.
Aug 14, 2017 | GE Microwave Ovens
GE Microwave will only run about 3 seconds, then shuts off. I've unplugged, let it sit and tried again. Same thing. Help!
I have a workaround for you, that works for other brands. I am not sure if it will work in your case though. Pls try it:
- It seems that the door closing sensor is not working well, so it might think that the door opened.
- Once you have this problem, open the door and then close it again.
Normally it should work...
Nov 21, 2012 | GE Microwave Ovens
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
I can't find the instruction manual and I have no idea how to use it>
Might it be as simple as going to a free download website? Start by typing in your model's number, then add download manual. I've got all sorts of s/h stuff working this way.
Good luck
Jul 23, 2011 | Microwave Ovens
I am disassembling a Kenmore stove top gas burner to clean under the stove top. To do so you actually need to unscrew the burners, which I've done, but then I need to unhook the spark electrode, which...
The electrode is held onto the burner head with a screw through the mounting tab. They can get crusted over and it's not always easy to see the screw head, but it's there.
Jul 04, 2011 | Microwave Ovens
Where can I find a replacement tray for an Emerson microwave MW8779W?
I've checked the places where I normally get parts, and also checked online. It looks like the manufacturer no longer supplies the original part. This means you either need to replace the oven, or see if a suitable tray for another oven might be available. This site is often mentioned as a good place to check, although I've never tried them myself. You could also check for appliance service shops or parts stores in your area that might be able to supply a generic tray that might work.
Good luck on your search and thanks for using Fixya!
Jun 01, 2011 | Emerson MW8779W Microwave Oven
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
13 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
