Question about Garden
I have a hard top roof for a 2011 4 door Jeep Wrangler. I want to use a pulley system in my garage to store the hard top just below the ceiling of my garage. I can then lower the roof onto the Jeep when I want to put the roof back on. Any starting point ideas?
  • 377 Answers
Did that once myself. For me, the first thing I learned was that wherever I needed the same exact length of "rope" I used chain. I wrapped the chain in the rubber insulation used on 1/2" pipe to protect the top where necessary. By using chain I just counted the links to get exact lengths and make adjustments where I needed to. I built a 2x4 frame to the size of the roof with the idea of having a chain come down in each corner to hook onto the roof. Also had chain going from each corner of the 2x4 frame to a common point I would lift from. Think of a 2.5 feet of chain from each corner meeting at a point above the roof. I attached a boat winch to the wall of the garage and through some pulleys I was able to winch the roof off and lower it when I wanted to put it back on. By using the chain I was able to make adjustments to height, tilt, etc. Hope this helps.
Posted on Sep 15, 2010
  • pwillitz Sep 15, 2010
    The 2x4 frame is not a "must". You can do it all with chains and rope. I just wanted the chains I hooked to the roof to hand straight down as opposed to coming down in one bunch on the top of the roof. I also had lots of height to work with.
    Again, hope this helps.
Diesel battery
How old is the battery? They dont last forever and cold weather takes the life out of them fast. Below 50 they dont like to charge, below 32 they loose half the power. Below 0 you are down even more and the engine is harder to start when it is that cold.
Feb 05, 2014 | Koolertron TM For 2007 2008 2009 2010 Jeep...
Tip
Tips for storing bicycles
Garage Storage: Tips for storing bicycles .Floor stands (shown below)<br />Children who ride bicycles often like to just drop them and run off. If you want to change this habit, consider getting a floor stand. Of all such storage devices, it's the easiest to use.Support posts (shown at right)<br />You can also lean bicycles or other large gear against a post. If you add elastic cords or hooks, the bikes will be even more secure. For two-story storage on support posts, look in a bike shop. The post shown here holds up to four bicycles. It works best in garages with high ceilings.<br />Pulley rigs<br />With a pulley system, you can store large items near the ceiling to preserve space below. You can buy a pulley system that works like mini-blinds. It has a built-in stop to keep items up. A gentle tug releases the mechanism so you can lower the object.<br /><br />Screw these pulleys directly to ceiling framing if the wood runs in the same direction you want to store things. Or attach the pulleys to plywood first and then screw the panels to the joists. You must use this method if the joists run crosswise to the pulley direction.
on Dec 21, 2010 | Cycling
2009 Jeep Wrangler inside door handle broke
i have just bought a peugeot 306 and it is making a catching noise a man in the garage said it is one of the pulley,s what can i do to fix this
Jun 28, 2012 | 2007 Jeep Wrangler Unlimited Rubicon 2...
I recently purchased a 1995 wrangler Rio Grande and the soft was replaced with a factory Mopar hard top and the soft upper doors are not a fit. They have sharp angled corners where the hard top has...
Contact Jeep and see if they have such a thing. If they dont then you will have to take it to a fabricator that can custom alter your doors for you.
Mar 30, 2010 | 1995 Jeep Wrangler
Not enough clearance from rafters to install the
Here is the information I think you need.
There is an accessory available from Sears and some home stores called a "low clearance bracket kit". It can be used on any sectional garage door that has clearance problems due to low ceilings or obstructions, allowing the garage door opener track to be mounted much closer to the top of the garage door than is usually possible.
The top guides (which hold the uppermost garage door rollers) on your door are replaced with specially designed brackets that cause the top of the top panel of the door to move inward further as the door opens than standard top guides. The result is that the top of the panel does not rise as high as the door opens, giving the additional ceiling clearance.
I have a photo of this item on this page: http://www.naturalhandyman.com/iip/infgar/infgar1f.html
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
07 wrangler is leaking water from the top of the doors
Stay on the Dealership and make them fix it. Persistance is key.
I had teh dealership service manager run a garden hose across my roof for 15 minutes before I would accept it back.
Don't let them use teh pressure washer hose, it bounces teh water off the top. You want a full soak situation like a real thunderstorm.
If they can't fix it, go to the next town and have them work on it. Performance does vary.
May 11, 2009 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Soft top-1993 Jeep Wrangler YJ
OK I have a yj and you start from the windshield put the snaps/or what ever yours is on the top of the doors then down the side or the doors then under the back side window then around the curve and this is the hardest part then your tailgate also make sure your bars on the inside are loseuntil the top is on then thighting those bars and you should have a nice tight top but belive me it is hard and you might need a flathead screw driver for the corners. Good luck and a jeep wave to you!
Apr 03, 2009 | 1993 Jeep Wrangler
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
