Question about Maytag MDE9206 Dryer
Cant seem to figure out how to replace belt, doesnt get any tension, please post picture
  • 262 Answers
cant seem to figure out - cd45e89.jpg This is a rough Idea of how to get tension on the belt.
Posted on Sep 15, 2010
Removing tensioner assembly
images for 2008 Nissan Versa Removing tensioner
    how do you remove tension off surpentine belt tensioner - Nissan Forum
    www.nissanforums.com/.../151350-how-do-you-remove-tension-off.htm...
    Feb 20, 2009 - 4 posts - ‎2 authors
    2008+ Nissan Rogue ... QR25 2.5L Engine Engine Discussion: 2002+ Sentra SE-R and SpecV ... how do you remove tension off surpentine belt tensioner ... changed these before, but which way do you turn the tensioner, how ... Replacing the Water Pump on a '04-'08 Maxima *DIY*
    1 post
    Aug 31, 2011
    Belt noise: replace idler pulley? - GA16DE
    Sep 16, 2008
    Step by step instructions -Upper Timing Chain Tensioner
    Dec 8, 2007
    Idler Pulley Bearing Replacement Info
    May 16, 2003
    More results from www.nissanforums.com
    Nissan Versa Tensioner Pulley Issue (1/1) - EricTheCarGuy ...
    www.ericthecarguy.com/.../50669-nissan-versa-tensioner-pulley-issue
    Nissan Versa Tensioner Pulley Issue 1 year 7 months ago #94552 ... for a 50 Torx to be used to remove the entire tensioner pulley assembly but all of my 50Trx
    How to Replace serpentine belt 2008 Nissan Altima ...
    ? 11:29
    https://www.youtube.com/watch?v=5NchA85pnAE
    Jul 2, 2014 - Uploaded by nivekoch
    How to Replace serpentine belt 2008 Nissan Altima In this video i'll be going ... 2005 Nissan Altima 2.5L serpentine belt tensionerreplacement ...
Dec 16, 2015 | 2008 Nissan Versa
HOW TO ALT BELT 94 GEO??
7aFE or 4AFE engine.
old post, if you cant figure that out. then post vin, post photo of it.
my guess is it is a V belt, be nice to all that.
and you did say ALT and ALT tilts.
the alt has pivot on the bottom, and the top has built in
belt tension adjuster there,
one gets all that loose, and use it to set tension on the belt
about 10lbs force mid span on belt and 1/2" deflection
almost all V bets set like this for 100 years, even a tin lizzy.
Apr 05, 2014 | 1994 Geo Prizm
How to replace alternator belt
Find the belt tensioner bolt and loosen it. There will probably be two other bolts that need to be loosened (just loosened not removed). Move the alternator to its " most slack position" pull the old belt off anf fit the new one. Push the alternator with a broomstick or something similar to tension the belt. (Be sure to push against a solid part of the alternator or you could break it) tighten the tensioner bolt. the tension should be set so that you can push the belt in about 20mm between the pullies with your finger. If the new belt squeels when you start the car the belt is too loose. Tighten the other two mounting bolts.
LPG
Sep 10, 2012 | 1999 Renault Megane
Looking for a diagrahn of a 2001 pt cruiser
The tensioner will be down lower and it will have a large metal roller wheel attached to it that is pushing against the timing belt to take the slack out of the timing belt, and you should be able to see it if the timing cover is removed, here is a picture of what you are looking for, and let me know if you still can not find it, or you require further assistance .5658e28.jpg
May 17, 2010 | 2001 Chrysler PT Cruiser
Alternator belt
The other belt has a tensioner and is located under the ac compressor. It takes a 8mm bolt to loosen it.
Apr 22, 2009 | 1998 Nissan Sentra
Audi serpentine belt problem
are you sure you put it on the right way go to autozone.com and get a belt diagram. did you put the belt on upsidedown?
Mar 07, 2009 | 2001 Audi A6
HELP! I cant find the tensioner on my 1996 buick lesabre serpentine belt
The belt tensioner is to the right below the alternator .
Oct 20, 2008 | 1996 Buick LeSabre
1998 dodge neon airconditioning belt adjustment?
This procedure involves correcting the tension on the power steering accessory and A/C compressor drive belt.
1. Loosen the power steering pump locking bolts A and B and pivot bolt C(Illustration 1 and 2 ) to allow adjustment of belt tension.
2. Using a 1/2" breaker bar, adjust belt tension by applying torque to the square hole "D" on the power steering pivot bracket. Adjust the tension as follows:
Belt tension with no belt replacement: A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 100 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
Belt tension with belt replacement:
A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 135 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to 27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
C. Start the engine and allow the vehicle to idle for 15 minutes to allow the belt to seat.
D. Repeat the belt tensioning procedure, set belt tension to 135 lb.
click here for picture 1
click here for picture 2
Jun 13, 2008 | 1998 Dodge Neon
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
