Question about Samson C01U Consumer Microphone
Samson 3o1u has a delay in my headphones - Samson C01U Consumer Microphone
  • Samson Master
  • 5,603 Answers
The delay is due to the time it takes to digitize the audio and pass the data through your computer to the audio board.
Depending on your system and software, you MAY have a setting for ECHO which loops the sidetone directely to your headphones so the delay isn't present/
Posted on Sep 15, 2010
No sound to my headphones with Samson mdr624
First be sue the headphones are good. The C/ROOM + PHONES control is used to set the level sent to the control room outputs, and also to the head-phone jack.
Nov 20, 2014 | Samson MDR624 Mixer
How to unmute a samson meteor microphone
Just press in the switch in the middle of the dial for the headphone levels on the mic.
https://www.youtube.com/watch?v=byun8WG2y1U
Jul 06, 2014 | Samson Meteor Microphone
Why is it delay the voice when im recording use samson c03
You need to reduce the buffer size of your DAW and use ASIO4ALL to get low latency monitoring.
Jun 09, 2014 | Samson G-TRACK USB RECORDING MICROPHONE...
H4n zoom wont record says card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 23, 2013 | Samson Technology Zoom H1 Recording Bundle...
Can a Samson g track mic be used with the new iPad?
Yes, but the iPad doesn't supply enough power for the G Track to run headphones, so you will need to use a powered hub between the mic and the iPad.
Jun 26, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Getting distorted sound when connecting from mac pc headphone jack to 1/4" line in input
You are connecting a NOISY unbalnced line to a balanced input. Buy a DI box and then use an XLR to XLR to the mixer inout and run the MAC into the DI with "ground lifted". You will need to make a resistive mixer between the headphone jack and the DI as well. The headphone jack is STEREO. You COULD try a STEREO 1/8 inch splitter to 1/4 inch left and right cable... you MIGHT get away with that. Right now the left and right amps in the MAC are fighting eachother.
Sep 25, 2011 | Samson New Samson Mdr-1064 10 Channel...
I can only hear one side of my headphone with the Samson S-Amp! wheni pull the headphone cable out i can hear on both ears. what kind of connection do i need to listen in stereo?
Are you using a STEREO input cable? Is the source of the audio stereo? The stereo cable will have three connections on the plug... the sleeve, the ring and the tip.
If you only have mono source or using a mono cable you will only get sound in the left headset. Pulling the plug part way out will sometimes contact both connection so you will hear both.
If your source is mon, you will need a special cable that connects the mono signal to both sides of the input plug, that is the ring AND the tip.
Mar 29, 2011 | Samson Samp Headphone Amplifier
What are some of the common reasons that my Samson S-amp headphone amplifier isn't working?
Most common reason probably would be incorrect or failed power adapter. It appears the unit requires a 18 VAC (not DC) adapter. Dead batteries if that is the power source would be the other cause to suspect.
Feb 28, 2011 | Samson Samp Headphone Amplifier
Samson Stereo Headphones RH100 - no more sound
first u have to check the wire from pc to headphone whether any wire is damaged ,next u check whether the volume in the headphone is mute, and then check the pc volume whether it is in mute .rate as u like
Oct 16, 2008 | Samson RH100 Headphones
Samson C01U Consumer Microphone Logo
180 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
