Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
After I installed my Badger 5 my dishwasher would not drain. Is there a plug in the dishwasher port on the side of the disposal and how do I remove it?
  • 377 Answers
There is often a plug in the ISE as many people use them without have a dishwasher connected to them. Quite often it is just a thin plastic membrane that can be knocked out with a screwdriver. There should also be a note to this effect in your installation instructions for the ISE.
Posted on Sep 15, 2010
  • pwillitz Oct 04, 2010
    I am sorry my solution was of no help to you.
    Paul
    New Friend:
I busted a few holes in the plastic (the flathead is sharper than I though) before I finally knocked it out. Keep pounding!!
Posted on Apr 09, 2013
I installed a new disposal must have missed th fine print about knocking out the drain plug, after going over all of the solutions for draining problems with the dishwasher. It took five min. to disconnect the drain line, find the plug half way into the disposal drain tube is a thin plastic plug. With a screwdriver and hammer knock it out. the plastic plug will fall inside the disposal make sure it is unpluged (power supply) reach inside through the sink and remov the plug. WORKS FINE NOW.
Posted on Jun 12, 2011
Installing new badger 5 do you have to drill hole in disposal for dishwasher to drain there is place but no hole
No you punch out the plug inside the fitting where the dishwasher hose goes.
Here is a link to the instructions look at step 15 and 16
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 disposal is leaking from the side whats wrong
Check where leak is coming from.
1) Run water until leak starts. Use dry paper towel near top of disposal to see if sink strainer is leaking.
2) Move paper towel down and check where dishwasher connects to disposal.
3) Move paper towel down to tubular drain tailpiece.
4) Water should run down side of disposal if sink strainer, dishwasher connection or tailpiece are leaking. You can fix these problems using tips below.
5) If disposal is rusted out, then water will leak out of bottom or side of disposal body.
There are no repairs or repair parts for disposals.
I wrote EZ installation tips for garbage disposal from when I worked apartment maintenance that will save time and sometimes money:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 19, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The diswasher drain connection is blocked in the new badger 5 that I just bought and installed and the dishwasher cannot drain and it runs up out of the drain line and goes out on to the counter...what am...
You are missing that the plug needs to be removed on a new disposer. All new units have this port sealed as not every install will have a diswasher...Take the unit out, and look in the hole, woopsies. Push it out with a screwdriver and a hammer. this blockage would cause the water to come out of the vacuum break on the counter.
Fortunately not a big problem to repair.
Oct 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I would like to know where the plug for the dishwasher drain in my new badger 1 disposal is?
#/4 of the way to the top there is a round pipe like thing sticky out from the side of the disposal...
Take a screw driver and pop the back out of the round hole to allow the water to get into the disposal...
Also dump the blank out of the disposal before operating it.
The just hookup the dishwasher discharge hose to the round hole and your are ready to go!!!
Heatman101
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I would like to know where is the plug for dihwasherdrain plug located ot he garbage disposal
It's not guaranteed that your particular model will have a dishwasher drain nipple, but it does, it'll be on the side, near the top of the machine. If the disposer is new you must knock out the plug inside the nipple before connecting a dishwasher. If the disposer doesn't have a nipple, you can get a piece of pipe to fit to the non-disposer side of the sink where you can connect the dishwasher drain hose.
Feb 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Attaching dishwasher drain hose.
Are you talking about the "barbed attachment" on the disposal? If so, simply use a screwdriver and hammer to knock it out. Make sure you reach into the disposal (through the sink) to get this piece of plastic out after. Good luck
Jan 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
May 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher drain fitting
if this was just put in it is most likely the packing plug was not removed when installed please take hose off and remove plug .
thank you for useing fixya
RATE ME
May 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
659 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
