Question about Dictaphone 1740 Desktop Cassette Transcriber / Recorder
The tape play gear will not turn - Dictaphone 1740 Desktop Cassette Transcriber / Recorder
  • 207 Answers
Hello you can sen your unit to service to this place
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Posted on Oct 09, 2010
Tape player will not play, but FF and REW work, as well as counter. model: Onkyo Integra TA2066
This unit uses a Sankyo type transport and after all these years and functions the feedback contacts may have become tarnished or the worm gear motor may have developed a dead spot. If you take the cover off the unit the first thing is to get a burnishing tool and work on the copper leaf contacts to see if that is it. This can be done with the power off. Then test the unit to see if that worm gear cam system will rotate. If not then the next course of action is to replace the cam motor as it has a dead spot on the commutator. You can confirm this condition by taking a small ***** driver and turning the worm gear quarter turn. Then try some play functions. If it works that is the problem. You will need to get a new motor and replace this- it is very involved and not an easy part to find and so a Technical person is better off doing this. If it does not move then it could be that the drive circuit is having trouble in either the supply or the drive transistors.
You will need to measure voltage in each direction it is suppose to turn. If it does not then on to the circuit board for the drive transistors.
Mar 30, 2016 | Audio Players & Recorders
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
Tape ejects when put it in. Will not play record rewind etc. It just immediately ejects.
Check the timing of the gears. they tend to slip.
Find the loading motor. It should look like a big battery with a worm gear on the side. manually turn the gear backwards and forwards a few times. Hope this gets you watching tapes! GOOD LUCK!
Jun 17, 2010 | Sony SLV-N500 VHS VCR
I turn it on to play for a few seconds then it stops. I think that the menu is set accordingly to play and record also.
Remove the top cover & have a look at the tape when it is in the play mode. Is the tape spilling on the right hand side? In other words there is no take up & the VCR will stop. This can be caused by either the belt or the clutch gear mechanism not turning the take up spool (it will depend on the model of VCR you have) either would best to be replaced.
Nov 23, 2009 | Sharp Televison & Video
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
My VHS tape is also stuck--tapping didn't help
does ur vcr have a idler wheel or gears (between both spindles?) if its an idler wheel, with rubber band it commonly can go bad. their a pain. unfortunately there may not be a replacemant part. if nopt, inspect the belt for cracks or glazing. it needs friction to spin the spindle to take up the tape being played. or if ejecting, to wind the tape back in the cassete. take off the cover of vcr and watch. if the right side wheel of tape is not turning while playing, theres ur problem. the tape is instead floating every whichway. another possibility could be a belt on the right spindle. if any bands need replacing, use an ordinary rubber band ,. should work just as good
Jul 31, 2009 | Televison & Video
Tape gets tangled in rca recorder
Your take up spool or the pinch roller on the deck mechanism is probably not turning & causing the tape to spill into the deck. The cause of this could either be the motor is not turning the pinch roller if a belt has snapped or the clutch mechanism is not engaging the take up spool. If you remove the top cover & take a look at the tape when it is in play or rewind mode you will see if it spills on the right hand side, look to see in the right spool in the cassette tape is turning. The remedy would be to remove the deck mechanism & check the gears or belts.
Jul 26, 2009 | Sanyo DVW-7200 DVD/VCR
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Tape deck not working
Possibly a slipping rubber belt in the tape unit drive is not gripping enough to complete an action and so is just stopping everything from happening until it completes that action. You might try GENTLY helping the belt complete its action.
Feb 23, 2007 | JVC MX-D302T Shelf System
Dictaphone 1740 Desktop Cassette Transcriber / Recorder Logo
44 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
NOEL
NOEL
Pennywhistler
Pennywhistler
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
