Question about Toshiba SD-V392 DVD Player/VCR
I`ve recently purchased a SDV398KC2 DVD VIDEO PLAYER VIDEO CASSETTE RECORDER and had to return it because when hooked up to my tv no picture showed when playing either vhs tape or dvd. After exchanging it, the second unit is this way as well and I tried it on another tv also with the same results. I`ve connected everything the same as my previous combo which worked fine until the dvd broke down which is why I`ve bought another combo.
  • 579 Answers
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Posted on Jan 08, 2008
SOURCE: Daewoo DF4501PN
is there a hack code for dvd recorder/ vcr combi to convert it to a region free player
Posted on Jul 18, 2008
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
Video output - yellow.
Audio output - left and right - red & white.
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
Posted on Feb 13, 2009
SOURCE: recorded dvd's won't play on other dvd players Toshiba d-r410
You can play these recordings without finalizing them in the D-R410, but if you want them to play
in other DVD players, they need to be finalized. See pages 28 to 32 in manual. If you want to
finalize the disks you've already made, follow the directions on page 32.
Posted on Jun 07, 2009
SOURCE: toshiba D VR660KU DVD VCR combo
The unit will only allow 2 hour recording on the DVD+R format. The DVD-R format is adjustable for longer recording time, just understand that the longer recording times = the lower the quality of the recording.
Posted on Jul 07, 2009
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
DVD/CD Player with Video Cassette Recorder
well deloris 137,
i would have to say that maybe some of your plug-in are wrong try switching your rca wires around. it the yellow, white, adn red cables. give it a try and i hope it helps a little.
Jan 28, 2009 | Microsoft Xbox 360 Console
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
External tuner
if it's possible attach a free-view box to it.
Jul 29, 2008 | Philips Magnavox DVD/VCR Dual Player
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Recording tv programs etc
I had same problem. With mine i could record wo the digital cable box but not with it hooked up. Would love to get some info about it.
Apr 27, 2008 | Sony SLV-D350P DVD Player/VCR
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
Toshiba SD-V392 DVD Player/VCR Logo
592 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
