Question about Car Audio & Video
Wire Harness for 1996 Ford Taurus
I am looking for a Wire Harness for a 1996 Ford Taurus. The problem I am having is: everywhere I go, they have the wrong harness for my car. They have these flat and long harnesses. Mine has 2 small ones. One is 16 pin and the other is 8 pin. Can anyone help my to find a wire harness for my car so I can finish my radio instillation? I thank you for your help.
  • KenJackson May 16, 2008
    Here is a blurry pic of the harnesses. The top one is 16 pin, the bottom one is 8 pin.
The harness you ar looking for is on the website metraoline.com you can get the harness number there ....ford taurus you may have to run wires on the drivers side becouse the amplifier is in the rear the face of the radio is just a controler so you will not be able got get speaker wires at the front of the car ...
Posted on May 16, 2008
I need an wire harness digram for an 03 ford taurus from the plug thats already run to the front. Any one have this imma just hard wire it instead of spending a lot of money so please if you have it
If you go to autozones website and make a free account and logon to that account, you can then put in the year make and model and look for the free repair guides. The electric diagrams are there.
Oct 09, 2015 | Ford Cars & Trucks
Harness i have a 99 ford taurus with three wires
If it is black the it most likely is an earth wire for the bulbs. H4 bulbs ( low/ high filaments accounting for the 3 wires. ) have an earth wire on the centre pin
Oct 05, 2014 | 1999 Ford Taurus
Where is the jumper wire harness
The usual place for attaching a code scanner is under the dash on the driver side. Some cars it is visible right under the dash - I have seen cars that the port is behind a panel or trim door. Your looking for the ODBC II port.
Jul 11, 2012 | 1993 Ford Taurus
Wiring harness does not fit transmission range sensor ford taurus. .took the motor and transmission out of 98 taurus and put it in a 96. the wiring harness is diferent. ax4s transmission and axod. i would...
Ask a trans repair shop,but I doubt it
The best you could hope for, would be to change the
trans wire harness.
I doubt the PCM will even work with the other trans
Should have rebuilt your AXOD
Sep 27, 2011 | 1998 Ford Taurus
Where is the washer pump located on the 1996 ford taurus
The washer pump is generally located on the bottom of the washer tank. Look for a wire and hose at the bottom of the tank where you add the window washer fluid.. Hope this helps.
Aug 18, 2011 | 1996 Ford Taurus
N.netMy 1996 Ford Taurus Transmission will not shift into 2nd gear, nor any other gear. Please help
sounds like your speed sensor plug or plugs it may have more than one usually held in place on the side of your ****** by a phillips screw and ring around it. and a detachable wire harness
Aug 02, 2011 | 1999 Ford Taurus
1996 Ford Taurus LX wagon. 3.0L 24v Duratec. Stalled leaving red light then no power at all. Towed home. Starter tests passed at home by manually putting power from B+ to 's' clip on starter. Starter also...
I would look at the positive cable at the battery and at the starter. Pull the cabel off and a continuity test to see if the wire has a internal break if the wire gets even a pinhole it can build corrosion on the inside of the wire and when a current is put through it it seperates (from the resistance and arc from corrosion) causing the wire to seperate internaly.
Hope this will get you started!
Oct 23, 2009 | 1996 Ford Taurus
My 1996 for taurus is out of time how do I replace the crankshaft position sensor?
You will have to disconnect the wire harness, then remove the cir-clip, and unscrew sensor very carefully and straight. Go to www.autozone.com and register for free full online repair manual with everything you could need for this car.
Sep 09, 2009 | 1996 Ford Taurus
1996/1997 Ford Windstar Audio wiring diagram
1997 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
96 and 97 are the same
Apr 07, 2009 | 1997 Ford Expedition
1994 Ford Taurus Station Wagon Steering Coulmn Wire Harness
i need to know to how to remove the power steering bracket on a 1994 ford taurus 3.8
Sep 23, 2008 | 1994 Ford Taurus
Car Audio & Video Logo
188 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
