Question about IBM ThinkPad T30 2366 Notebook
I have to press the power button numerous times to power on.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
I need code for kenwood kdc w707 can anyone help
There are a few types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Aug 31, 2009 | Kenwood KDC-W707 CD Player
How do I set the time and date for the fax on my Xerox Phaser 3200MFP
From xerox.com support for Phaser 3200
NOTE: If the printer has been powered OFF for a long period of time, the date and time may need to be reset when the printer is powered back ON.
  1. Press the [Menu] button on the Control Panel until 'Machine Setup' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button on the Control Panel until 'Date and Time' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Refer to the table below to enter the current date and time using the numeric keypad.
    Unit
    Range
    Month
    01 - 12
    Day
    01 - 31
    Year
    four digits required
    Hour
    01 - 12 (12-hour mode)
    00-23 (24-hour mode)
    Minute
    00 - 59
    NOTE: By default, the clock mode is set to the 12-hour mode; however, the clock mode can be modified to the 24-hour mode. See the Related Items below for additional information.
    Press the [*] or [#] button on the numeric keypad to select 'AM' or 'PM' for the 12-hour mode.
    If a mistake is made, press the [Left] or [Right] arrow button to move the cursor under the digit to be modified, and then enter the correct digit using the numeric keypad.
  5. When the date and time are correct, press the [Enter] button.
  6. Press the [Stop / Clear] button on the Control Panel to return to the Standby mode.
Jul 29, 2009 | Xerox Phaser 3200MFPB Multifunction...
What is the lock code for kenwood - kdc-x589
There are afew types of override procedures for Kenwood.
Type 1
Type 2
Type 3
Jul 23, 2009 | Kenwood KDC-X589 CD Player
Lost code for my kenwood kdc-w707
There are 2 types of override procedures for Kenwood.
Type 1
Type 2
Type 3
Apr 05, 2009 | Kenwood KDC-W707 CD Player
Set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Feb 26, 2009 | Canon MP-25DV Calculator
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
IN 120 base keeps flashing CL
- press the OK key
Jul 09, 2008 | Lands Phones
Cd code on radio kenwood
You need the remote control to clear the code, if you don't have one, then you may need to go to a KENWOOD agent, or purchase one for your use.
KENWOOD SECURITY CODE CLEAR procedure Your code number is 5227 (KCAR)
Your radio will require one of the following procedures.
Type 1
Type 2
Type 3
Please rate ne FixYa for this solution. Good Luck :)
Jan 30, 2008 | Kenwood KDC-MP4028 CD Player
Display
try this
Type 1
Type 2
Type 3
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
IBM ThinkPad T30 2366 Notebook Logo
56 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
