I HAVE A SWINGLINE 69008 ELECTRIC STAPLER. THE STAPLE CARTRIDGE KEEPS POPPING OUT.
4 Suggested Answers
goalie39
  • 469 Answers
SOURCE: stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Posted on Apr 30, 2009
SOURCE: Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
Posted on Jun 25, 2009
  • 6 Answers
SOURCE: Stapler (Swingline 211xx) has jammed. It is electr...
Turn the stapler over, remove the batteries, then remove the black pads and the four screwa under them. Take off the bottom cover and you will see the clear tabs of the cover sticking through the bottom plate. Pust them with a screwdriver toward the center of the stapler while squeezing the cover from the other side. Chances are that you will find the plunger that drives the staples is misaligned. Bend it gently forward or back until it moves without binding. Good Luck!
Posted on Feb 16, 2011
Swingline model 67 broken staple driver part replacement
you buy a new stapler . they do not make that part as a replacement
Aug 27, 2016 | Swingline 06702 Model 67 Electric Stapler
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
We have a Swingline 690 electric stapler in our office. We are unable to get the stapler to work after loading staple cartridge. We followed the directions and made many attempts to load. There does not...
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Mar 30, 2011 | Swingline Portable Electric Stapler
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
Cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
996 people viewed this question
k24674
jasbo
jasbo
