Question about Roper Dryers
My roper electric dryer was working fine then i put a load in and it wont turn on. Yes it is plugged in. Do you have any idea what it may be?
  • Roper Master
  • 3,361 Answers
Yes,I have a good idea.
First,take your volt meter and verify 220 volts are in fact coming to the dryer terminal block.
If it is,unplug the dryer.
Remove the rear panel.
Set your volt meter for ohms.
Unplug the thermal fuse located on the left of the main exhaust vent.
It is 1 and 1/2 inches long by 1/2 inch wide and white in color.
Touch the 2 meter leads to the 2 terminals on the thermal fuse.
No trading is a bad fuse.
Replace it.
If the fuse gets a reading it is OK.
Then,open the top lid from the cabinet and check the door switch for continuity.
If there is no continuity,replace the door switch.
Posted on Sep 14, 2010
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
I have a Roper dryer and it just turns off we can
first thing to do is to find out whats wrong with the cord, get to the part of the cord that goes into the machine, wires are loose. a 220volt dryer will not heat if one of the wires are loose. you need to get into machine and make sure wires are tight. this is also a safety hazzard, do not leave machine plugged in until problem is solved
Sep 02, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer model res7648kq0. wont turn on or heat ?
On the back side of the dryer sits the heater and various safety clixons. Any of them that would be OPEN ( no continuity) would be the problem. Here are some repair pictures
Jul 25, 2009 | Roper RES7646KQ Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper dryer
check thermal fuse
Jul 18, 2008 | Roper Dryers
Dryers Logo
47 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
