Question about Poulan PP4218AV 18" Chain Saw
Hello, My pp4218avx starts up cuts for about 5 minutes and dies when hot, will not start till cooled down. Already changed spark plug and made some adjustments. Any help will be greatly appreciated
Sounds like the ignition module. Have you tried replacing that?
Posted on Nov 11, 2010
JD JS45 walk behind mover. Starts, runs fine for 5 minutes, then stalls, won't restart till i pull the spark plug and cool the motor, plug down. then same thing starts, runs for 5, stalls.
Probably either a fuel or a spark problem. You need to check for the presence of a good spark immediately the engine stops - by using a spark gap, a spare spark plug or a propriety spark indicator.
If the spark is found to be absent the fault is likely the ignition module but check all connections and the stop switch operation before replacing.
If the spark is present then the fault is probably fuel-related and is the sort of thing a tiny droplet of water in the carb could cause...
Jul 23, 2016 | Cars & Trucks
Engine runs well for 40-60min then shuts down.
sometimes when a spark plug or the coil is going bad it will run till it gets hot then die. after it cools off it will start and run fine. till it gets hot again. replace the spark plug if that don't fix it you may want to start looking for a coil.
May 19, 2016 | Garden
My 2600 troy bilt pressure washer starts and pumps for about 4 minutes then it cuts off, my question is why ?
could be several things. replace the spark plug and try it again. if that don't fix the problem then the coil may need to be replaced. when an engine gets to operating temperature or hot some times the spark plug or coil will start breaking down and it will die. after it cools off it will start again.
Apr 07, 2016 | Garden
Does not start after 5 min of runing
the past few mowers i have worked on the people are saying the same thing. runs for a while till it gets hot then dies and wont start till it cools off.. all of them have valves that were out of adjustment. when you go to start it does it want to stop or hesitate at a certain spot? if so it is valves need service. try a new spark plug. plugs may break down when hot and just need replaced. hope this solves your problem.
Mar 03, 2016 | Garden
L2050 kubota tractor after engine gets hot if i shutdown it will not crank over after cool down starts back up.
Nest time it is hot and does not start, check for spark. U could have a thermal issue where the ignition coil gets hot and stops working till it cools down.
U mentioned glow plugs - is this a diesel powered unit? Check for proper oil level in unit? Oil pump? Poor lubrication will cause an engine to expand when hot and not restart till it cools down.
Oct 13, 2015 | Kubota Garden
My husgvarna staggers after a while of cutting then dies whats the problem
i am going to guess that it won't restart immediately after it dies either. It sounds to me like an ignition module going bad. it gets hot then cuts off the spark, once it cools down it starts and runs again until it gets hot again
Feb 27, 2013 | Garden
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1988 3.8 olds cutlass Ciera stalls, no spark until it cools down
Check the prrimary and secondary resistance on your coil. Also check the resistance of the plug wires and plug gap.
Aug 12, 2009 | 1988 Oldsmobile Cutlass Ciera
Testing ignition coil
it sure sounds like the coil, you already did the test.
Jul 11, 2009 | 1995 Suzuki GSX 1100 GS (non US...
Poulan PP4218AV 18" Chain Saw Logo
276 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
