In rinse water does't shut off. Just keeps running and overflowing.
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Why does the Water valve keep running water when bowl is full?
Because the shut off point is above the overflow tube. You will need to either adjust the arm or bend the float end of the arm downward to make the arm end swing higher to reach the shut off point prior to water overflowing into the tube.
Apr 27, 2014 | Korky Waterwise Toilet Fill Valve 528Z
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Have a fluid master valve--I believe it is a 883B--fills the toilet and appears to shut off but very slowly keeps filling. Never actually shuts off completely..Please Help!!
there are only 2 possibilities; 1 the tank seal is leaking into the bowl and the input valve runs to replace the water lost, or 2, the water inlet valve does not shut off totally and the water continues to flow into the bowl via the overflow tube in the tank.
If the water is running into the overflow tube, adjust / replace the input valve, if the water is not going into the overflow valve, clean / replace the flapper valve at the bottom of the tank.
Please let me know how you make out.
Aug 25, 2011 | Home
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Water overflowing and never shuts off
Jammed solonoid valve open position.....
Nov 02, 2009 | Frigidaire FWS1233F
I was an idiot and put dishsoap in the dishwasher because I ran out of regular dishwasher soap. Now the dishwasher keeps overflowing with bubbles. I keep wiping all the bubbles and extra water out but...
you must rinse all the soap out the best way is to make the drain hose lower than the tub of the washer and run the garden hose into the drum and slowly rotate the drum as you rinse it out after a complete rinse you should run a rinse and spin cycle a few times and you should be fine.
Aug 27, 2009 | Dishwashers
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
May 12, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Water won't shut off during wash/rinse cycles & overflows
the clear tube going from the tub to the pressure switch probably came undone or has a hole in it
Apr 24, 2009 | Washing Machines
Kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Water keeps running will not shut off causes and overflow
If it only overflows while the washer is running, check the pressure switch, or water level switch. The hose may have come loose, or could have a hole in it somewhere. Otherwise the switch may be stuck or may need to be replaced.
If it's overflowing when the washer is off (i.e. in the middle of the night when there is no laundry in it), then check the water valve.
Mar 26, 2008 | Hotpoint VBXR1090B Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
