Question about Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV
Where the g board located on sony kdp-51ws655?
  • 2,318 Answers
Check the picture below to find the G board on your TV.Where the g board located - 719e390.jpg
Posted on Sep 14, 2010
  • 6 Answers
See pictures below for the "G" board AND the most probable failed components:
Where the g board located - g-board-located-4ojfzua2t5qdonett1db0kz0-1-0.jpg
Location of "G" Board
Diode 6301 (must be desoldered from back and replaced with Nihon 10erb20-tb5) Cost: Less than $10. TRY THIS ONE BEFORE ATTEMPTING TO TACKLE THE NEXT ONE. REPLACE D6301 AND THEN RE-CONNECT THE "G" BOARD AND ATTEMPT TO POWER-ON THE TV. IF YOU GET THE SAME RESULT, CONTINUE ON WITH REPLACING D6116:
Diode 6116 (must be desoldered from back and replaced with Nihon 10erb20-tb5) Cost: Less than $10
Posted on Feb 11, 2015
2 Suggested Answers
  • 14 Answers
SOURCE: red lite blinks tv will
Check out
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Posted on Oct 02, 2010
G board locating diodes
Google "Diode photo" if you do not know what one looks like--are all similar in appearance but different in size and functions.
note the silver band on left here--cathode or positive end of diode.
Apr 18, 2012 | Sony Grand WEGA KDP-51WS655 51" Rear...
It will turn on somedays and work great other days nothing red light blinks 10 times
Thats a HV issue which is indicating that there is most likely an issue with the any of the following items all located on the D board. They are:
Transistors Q8013 & Q8014
Resistor R8051
Integrated Circuit IC8005
Aug 31, 2011 | Sony Grand WEGA KDP-51WS655 51" Rear...
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony KDP-51WS6755 not turning on, power surge, pop, 6 blinks.
unplug it immediately. never tolerate a sizzle (frying noise) or a popping noise. do NOT replug. fire hazard.
contact serviceman for repairs. Sears Home Service can handle this for you.
Apr 14, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Part number for mirror in Sony KDP-51WS655
Sony Part Number: 2-023-094-01 I WENT TO A WEB SIGHT CALLED WWW.PARTSTORE.COM U MAY WANT TO GO THERE AND MAKE SURE ITS WHAT YOUR LOOKING FOR IT SAID A MIRROR (51)
Mar 07, 2009 | Sony Grand WEGA KDP-51WS655 51" Rear...
Model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
Oct 26, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony KDP-51WS655
how many times does the light blink?
Feb 19, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sont kp-46wt510 blinks 4 times
IC1509 8-759-593-33 IC LA78045 35.98
Q1505 8-729-423-33 TRANSISTOR 2SC3311A-QRSTA
Replacement part
8-729-119-79 TRANSISTOR 2SC2785-FEK-HFE 1.02
these ic locations are different than yours but same part number.
is there a 2sc3311 near by LA78045?
Jan 10, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony KDP-51WS655 Need part and info
The cn6001 part number is 1-580-843-11
The Diode part number is 8-719-843-11 (both diodes are the same)
Oct 31, 2007 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony Grand WEGA KDP-51WS655 51" Rear Projection HDTV Logo
813 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
