DVD+/- Gateway issue DVD won't burn DVDs but plays them
Hey I've been having the same problems as some of the other folks thats replied above. I can watch dvds and record cd's fine, but to no avail can I burn a damn dvd. I have used these plain white dvd's ( but I know they work fine because I've used them before to back up music and other files and they've been great) but for some reason the dvd burner won't work now to burn . The cds, like I said will burn fine. I've tried Ashampoo, Cyberlink, Cheetah and they all won't work for the burning of a dvd and the Ashampoo usually always works fine. I had Gateway do a remote desktop & we've checked the drivers and used the uninstall and scanned for hardware changes etc. included is a little info about my system. Hope this can help you figure out whats the problem. Sometimes I've noticed that my drive fort cd/dvd player ( which is F:) will say cd then at times it will say DVD and it's totally got me confused. Thank you and God bless
Cheetah log file: Cheetah Log
Initialize
OS Type XP
ToolBar Set
Register - Begin
Register - Begin end
getLastPosition
runMode mp3_disc
isBrowserShowing True
------------------ Data Disc -------------------
Loading drive data...
getSettings
initialize drives
F: HL-DT-ST DVD-RW GWA-4165B DG01
Disc Media Type - 3
Disc Open - True
Free Space 4488.06 MB
Space Required 1.44 MB
Your Drive can burn these Disc Types...
CDR
CDRW
DVDR
DVDRW
DVDPRW
DVDRDual
initialize drives
Disc Media Type - 3
Disc Open - True
CDR
CDRW
DVDR
DVDRW
DVDPRW
DVDRDual
initialize drives
Disc Media Type - 3
Disc Open - True
CDR
CDRW
DVDR
DVDRW
DVDPRW
DVDRDual
computer specs:My Computer Information - General
Refresh screen
Specifications
Gateway
System Model: DX210X
BIOS Version: Phoenix Technologies, LTD 6.00
PG
Operating System
Microsoft Windows XP Professional
Version: 5.1.2600
Service Pack: 3.0
PID: 76487- OEM - 0011903 - 00806
Hot Fix: KB936929
Memory (RAM)
Capacity: 1.50 GB
Processor
Intel(R) Pentium(R) 4 CPU 3.00GHz
Version: x86 Family 15 Model 6 Stepping 2
Speed: 3000 MHz
General Computer Info
System Name: YOUR- 9466FB2976 Domain: WORKGROUP
Time Zone: Central Standard Time Connection: Workstation (standalone) Proxy Server: Auto
IP Address: 192.168.15.2
IPX Address: Not Enabled
Local Disk
Total Capacity: 298.09 GB
Sum of Hard Disks: (C: D: E: )
Used: 202.71 GB Free: 95.37 GB
Page 1 of 1 My Computer Information - General 5/16/2008 hcp://system/sysinfo/sysInfoSum.htm
Thank you again.
Ollie
  • Anonymous Feb 24, 2009
    says no disc is in drive E. There is a disc in the drive/
I had the same problem. I finally got a knowledgeable tech at Gateway who knew that a patch had to be downloaded. I'm sorry but I don't have the link anymore but you might be able to find it in there white papers now that you know that it exists
Posted on Mar 11, 2010
Some DVDs work, others do not
i have delt with the same problem the burned disks are only readable by a computer, or your burning software is meant for computer to computer burning, or the dvd players laser is just not strong enough to read the disks i can play some movies on one player and not so many on another
i hope this helped
Aug 22, 2012 | Vizio VBR231 Blu-Ray Player
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
Just bought an ONN dvd player and will not play burnt dvds. It says it will play DVD-R/RW. Any ideas to why it won't?
Burn your dvds in a proper way. If you burn your dvds as data dvd, it may not work on certain dvd players. Try different software or different PC to burn your dvds. Check the region code of your dvd player & the dvds burnt. They should match. You may find some region-free players.
sonsunny
Jun 19, 2011 | Televison & Video
DVDS WRITE BUT CAN'T PLAYBACK
use nero to burn it and make sure wat your playin it on supports those dics
Dec 22, 2008 | Gateway GT5220 PC Desktop
HR 720 does not burn to DVR -R media
Hallo everybody,
this guy "mysus" is a genius! I have had above problem on a Samsung HR-725 (160 Gb Version of the HR-720) now for approx. 1 year. I´ve called the Samsung Hotline and tried other dealers - nothing worked. Today I came accross this help and tried it out immediately - and it works perfectly. However, you do need to know a little about PCBs and electronics.
I used a variety of different -R DVDs and they all seem to work now. Many thanks once again for this fantastic link.
May 01, 2008 | Samsung DVD-HR720 DVD Recorder
WONT PLAY COPIED DVDS ANYMORE
were you able to play copied dvd's on this unit ? if yes then check setting on the dvd menu for things like DVD REGION and DVD playback speed and types of DVD playable, this is quite likely as i ha this problem on a pioneer model previously.
do those copied dvds no longer play on the same unit ? and you have tried them again on another unit or dvd player ?
rather i suspect problems with the DVD burn itself and its compatibility with the dvd player you are palying them on now (asuming settings in DVD enu are correct as loosely outlined above in point 1)
it may be that if this is a new dvd player than the one you played them on before, the dvd's may have to be closed in a certain way using your burning software so that they are playable on standard dvd players.
please also check that region is not an issue and that the recording speed of the dvd (the rip speed) is not too high or too low for your unit, as this data is stored on the written dvd and is responsible for the quality of the palyback data.
Mar 08, 2008 | JVC TH-M303 System
Dvd wont play
I wonder if you are trying to play burned dvds, if so that could be a major issue alot of players won't play burned disks, others will only play certain ones. another thing I have had problems with, though i don't know a fix. My samsung sometimes has a similar issue where it flat out will not play certain company dvds.
Jun 19, 2007 | Zenith DVB312 DVD Player
Computers & Internet Logo
798 people viewed this question
David Payne
David Payne
