Question about Frigidaire Freezers
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound coming from the unit, unusually quiet! I changed the temp setting to cooler, heard a click sound, and the compressor starts humming, sounds like it's trying to work. After about 5-10 seconds I heard a loud click and the humming stopped. After a minute or two, I can repeat this. It seems like something is possibly overloading a circuit and automatically shutting off the compressor. I don't need to reset a circuit breaker or anything like that. I left the temp setting at "6" with the unit still quiet, to go and research online. About an hour later I returned and found the compressor humming and the interior compartment seemed like it was getting cold again, as it should be. We haven't touched the temperature setting control all these years until today. Could the refrigerant be getting low or something? Right now the unit appears to be working OK, but I'm concerned. I'm wondering if this is the beginning of compressor failure, or something else to be concerned with.
  • 32 Answers
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Posted on Sep 16, 2010
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
We purchased a small haier chest-type freezer in 2006. It has worked fine until the past week. It seemed to be running normally, but suddenly did not keep the food frozen solid. There was a little ffrost...
You may have a refrigerant leak. First make sure the lid has not warped and leaving an air gap for heat to enter. That's really about all you can do without getting a tech. involved.
Jan 01, 2018 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
The alarm light is flashing, the freezer seem to be working,
Most all cooling systems need to be in an ambient temp of about 60-65 degrees. If not, it needs a low ambient control. This helps keep the high side pressure high enough so you have the proper pressure drop accross the expansion device. This applies to coolers, freezers, a/c units, and so on. I also think, if it keeps things frozen like you want, where's the problem? You make have a control just acting stupid.
Feb 07, 2009 | Freezers
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Freezers Logo
354 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
