Question about Microwave Ovens
Can a snapped Paddle for the icemaker be replaced by the consumer?
  • Microwave Ovens Master
  • 3,361 Answers
Yes.
Posted on Sep 14, 2010
How do I replace parts on the door of the GE Profile Advantium 120 Microwave
the door will come apart so you can screw it in from the inside its pretty easy just lay it out so you dont lose parts same with the clips they shoud either snap in when you have door apart or screw it in its just time consuming and terious work buy its do able
May 01, 2012 | GE Profile Advantium 120 Wall Oven
Where can I purchase a replacement drum paddle lifter for my old bauknecht tumble dryer TRA965?
HELLO.
The best way to get the drum paddle replacement is to visit the manufacturer website to order for it stating the microwave oven model number and give your house detailed address.
However the
drum paddle can also be purchase at any microwave oven authorized dealers around your local area with the model number for compactibility(easy use).
Thanks
Sep 21, 2011 | Microwave Ovens
I have a Technique bread maker Model:CETTR875 and need to purchase part #P/N22823 kneading paddle. can you help me?
Here is a direct link to a new paddle for that bread machine currently available on Ebay for about $18 US plus shipping:
http://www.ebay.com/itm/Cooks-Essentials-Breadmaker-Paddle-0-CETTR875-/200588189792?pt=Small_Kitchen_Appliances_US&hash=item2eb3fce060
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and item at the website indicated.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 25, 2011 | Microwave Ovens
The paddle has stopped turning. after removing the paddle you can see that the spindle turns.
My guess is that the spindle is cracked at the bottom; it will turn by itself, but can not move the tray. You can check that by dropping the bottom plate (with the lights), and taking off the drive motor. It could also be the motor itself; it has very small plastic gears inside which break easy, especially if you put heavy things in the oven.
May 08, 2011 | Microwave Ovens
We have been delighted with our breakmaker until lately when the paddle stays inside the bread when we lift it out of the breadmaker. When we retrieve the paddle this leaves a large hole in the bottom...
You haven't stated the make and model, but your problem is entirely normal operation on most breadmakers. In your case it's likely to be due to some wear in whatever holds the paddle onto the shaft, but to determine the exact cause is impossible by remote diagnosis as it requires a physical examination of the parts, sorry.
Remote fault diagnosis has it's limitations, unfortunately.
Oct 08, 2010 | Microwave Ovens
LG RefrigeratorModel LFX25960ST - icemaker has been replaced once
Most ice maker heads cost less than $49 to replace if you get it at a wholesaler. The water quality going to it will effect how long it will last, Reverse Osmosis treated is the best, filters will help some but are not a cure. Your budget is the determining factor in this equation.
Nov 21, 2009 | Microwave Ovens
Samsung microwave door handle snapped off and I found replacement parts but How do I get to the back of the handle to replace it?
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 18, 2009 | Microwave Ovens
Microwave broken door handle.
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Apr 23, 2009 | Microwave Ovens
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
