Question about Panasonic TH-50PX75U Plasma HDTV
PT-53TW53 ??? i have a red wave running horizontal you can see a double image of everything on tv, like if there was a magnet on the bottom of it ???WARPED PICTURE
I have a problem that my pc is not connected with data cable?
Posted on May 16, 2008
  • Asmeretina May 16, 2008
    My problem is the electronic technician software is not runing well it gives me error. why?
Panasonic pt-53tw53 location of my stk chip
my tv panasonic PT-53TW53G turn on red light on tv no pictur on sound
Jan 06, 2012 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red ,Blue and Yellow lines off,curving inword from top and bottom
Its failure of 2 convergence out ICs and requires replacement.
You can replace these ICs if you have basic electronics knowledge and good soldering experience. let me know to provide you more info about parts.
Feb 20, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Double image the second showing in red PT 53TW53G
replace the convergence ic's or look for loose connections that should do the job
Dec 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence
did you check the low ohm resistors? Its not uncommon for some of them to be opend when the ICs go out.
Oct 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53 53 in with bad picture
Sounds like you need new convergences ICs. There are two of them in your set sometimes you can get away with just replaceing one of them but I wouldn't recommend it. They are not too expensive are 15.00 each once you replace them you have to get into the service mode and adjust the convergence.
Sep 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Projection Tv Problem
The problem you are seeing is a convergence problem. This is a common problem and is fixed either by resoldering bad connections on the convergence ICs or replacing the ICs. These are large black ICs attached to a heatsink and are marked STKxxx. Try resoldering the pins on these ICs first.
Dan
Mar 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-53TW53
more than likely its your convergence amplifier ICs and if you can solder you can repair it yourself really easy.
Jan 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53g March 2004
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic TH-50PX75U Plasma HDTV Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
