Question about Black & Decker Hedge Hog 24-Inch 3.0-AMP Dual Action Hedge Trimmer #HS2400
Hedge trimmer locked up after binding - Black & Decker Hedge Hog 24-Inch 3.0-AMP Dual Action Hedge Trimmer #HS2400
3 Suggested Answers
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
I have an electric Bosch hedge trimmer, new ish. Just caught it on some metal, now it is making a high pitched noise and starts to smoke if I continue to use it. Have I wrecked it?
Sounds like a bearing is stuck and overheating when you use it. If you can get to the bearings, spray some lube in them like PB Blaster, and see if that helps. It's also possible that the blades are binding and causing the motor to overwork and the brushes are cooking. One or the other.
Jan 24, 2015 | Electric Garden
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
Electric hedge cutter,blaDES STICKING,hit them and they go again,plenty of power in the motor but blades sticking getting worse all the time
Could I suggest maybe using some dry lube on the blade surfaces, such as graphite or anti-seize compound? It can only help. I also recommend maybe a close inspection of them to identify the bind point and why they are binding at that point.
Aug 13, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
My Hedge trimmer will start and run for 2 or 3 minutes, then it dies and will not start again until the next day. Any ideas what is wrong?
Withou make and model it's tough to be accurate so I'll need to make a presumption that it's electric.
First clean the blades thoroughly then spray them liberally with a light oil like WD40
It sounds like the blades are binding and causing a thermal shutdown of the motor. Allowing it to sit over night resets the thermal circuit breaker
May 24, 2011 | Black & Decker 22" Electric Hedge Trimmer
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Black & Decker Hedge Hog 24-Inch 3.0-AMP Dual Action Hedge Trimmer #HS2400 Logo
69 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
