Question about Bosch Nexxt 500 Dryer
Went to put wet colths in dryer would not turn on
  • Bosch Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
My Samsung gas dryer displays error code u100. what is the meaning?
check igniter, flame sensor and gas valve and coils? if no gas from valve you will have no flame ignition. hence no heat, bad igniter will not ignite flame either, bad sensor will not detect flame hence no signal to ignite check all with multi meter
Feb 10, 2015 | Samsung Dryers
How many ohlms on thermo fuse test ?
Zero, should just have continuity, if there is no continuity the fuses burnt
Aug 09, 2014 | Maytag Dryer Repair Part - Dryer Lint...
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
Hi, My dryer has stopped dying the my cloths is this a common problem?
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Aug 31, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer leaves brown marks on white colthes
Likely coming from the rear seal being worn ot and brittle. Eric
Aug 08, 2009 | Whirlpool LER4634J Electric Dryer
My colthes dry a little then E1 flashes, what is the problem?
HI, the Thermistor is stuck open. you will need to replace this failed part asap. this will fix the issue and, restore your machine.
(E-1-- Open Thermistor)
Jun 08, 2009 | Whirlpool GEW9200L Electric Dryer
Magtag Electric Dryer
Did you check the breaker closely. Dryers work on 220 volts, usually 30 amps and that means TWO 110 breakers attached together must be good and putting out 110 volts each. One may be burnt or disabeled and the other working. Also check at the  dryer receptacle and make sure you have 220 or more volts.
Mar 11, 2009 | 2001 Yamaha V Star 1100 Classic
My sony cybershot got wet
    In this situation don't turn your product on ever untill unless you must sure that the wetness been remove into its inner.For this you have to take some percautive measurs,Which are
1- Get out the bettery from battery compartment.
2- In day light put a cotton cloth on you product and keep it in sunlight for couple of hours (cotten colth is for safty purpose,Because dont put the product in direct sunlight)
3-  After the completion of the sun light or also you can use bulb light for eveporation, If you have blower then dar it from blower.
4- Then after wait for minimum one day.Then turon it on and it will start working fine again.
Hope you will understand all the procedure.
THanks,and dont forget ot rate.
Nov 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
46 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
