Presario v3000 hi, in last 3 moths i have pressed more than hundred time F10 KEY, but the result is ENTER PASSWORD OPTION. pls tell me as there a way except changing the motherboard. pls reply jan
  • 2 more comments
  • madhusudanmv May 16, 2008
    I have given to 3 service center,they will keep for some days and they will say bios ic not found on the motherboard, and they have tried removing all the battery for quite some days , but the result is same.
    yes ,$450 for changing the board,
    no, I an from bangalore
    hi, there is tat4u from fixya, how to contact him, he has got some solution for dv2000.according to manual v3000 and dv2000 are same ,is it possible to contact him.
    pls reply
    jan
    Guru:
  • 1,894 Answers
One way is bypassing. which can be done at chip level servicing only.
else there is a option like we can use any tool like ERD.. but we cant assure that u will get solved by that method.
only sure shot method is chip level servicing.
so u should take it to company(if with in warranty) else take it to some local service centers.
Posted on May 16, 2008
  • 1 more comment
  • dewan nafees ahmed May 16, 2008
    then there is no way i think other than replacing the mother board.
    have u taken it to Compaq?/ are they saying the same?
    are u from chennai?
  • dewan nafees ahmed May 22, 2008
    use the ask me feature of that expert to post ur question to him
Acer aspire 5315_2826 laptop wont boot all tje way I tried it all the F.key numbers it tries to recover but shuts down fast pls help
HI
When you press the power up key please press the F8 key to see if this will take you into
the repair options
if it does then try the last known good configuration option
or the repair my computer option
if this does not work
then please try this
press power on key
then straight away press the Alt+F10 keys together
this will hopefully take you into the factory recovery options
unfortunatly for some this will reformat your hard drive and you will loose
anythnig that you personaly put onto the laptop
if you are asked for a password please try the acer default one
which is 6 zero's 000000
hope this has helped you
many thanks
Aug 02, 2011 | Computers & Internet
I have laptop compaq presario v3000 i have set bios password and now i forgot my password so is there any way to break the password, i had disassembled and assembled full laptop than also it doesn`t...
!BIOS is a freeware utility which is designed to be a whole BIOS and security suite. It has the ability to decrypt the passwords used in some of the most common BIOS makes such as Award, Phoenix, American Megatrends, IMB etc..
It also has the ability to brute force the password (known as "blasters"). However, this method is dangerous and can result in some unexpected and unwanted results. Note: Because of this applications password cracking abilities, some antivirus software may report it as a virus/trojan. This is a false positive.
To start using !BIOS, reboot your computer and take note of the BIOS type and version you are running. For example, If your motherboard uses Award BIOS you should look for the text "Award Medallion BIOS 6.0′ or something similar.
Download !BIOS from here and save it to your desktop. Then, open a DOS command windows by going to Start > Run and type: cmd
Once you see a black screen in front of you, type: cd desktop
You should now see something like: C:\Documents and Settings\YourUserName\Desktop>
Now type the name of the file you just downloaded, if you haven't changed the name just type in: bios320.exe
Use the down arrow and choose "Crackers" and then press the right arrow. Using the up and down arrows, select the BIOS that the motherboard is using and press Enter.
You should now see a menu asking what you want to crack, in most cases its the Supervisor or System Passwords you want to crack, so press the 1 key on your keyboard. It will then show you another menu asking how you want it to be cracked. Option 1 is pretty good so try that first by pressing the 1 key on your keyboard. You should now have your BIOS password.
Reboot the computer, enter the BIOS and try it out.
May 12, 2011 | HP Compaq Presario V3000T Notebook
Set up bios hp compaq presario v2000
1. restart you computer and enter bios screen by pressing f1 or f10 at first screen
2. set bios as you like, or press f5 tkey to load the default bios configuration
3. select yes using arrow key, and then press enter
4. press the f10 key to save the setting and exit
5. select yes using arrow keys and press enter
for more isformation about hp compaq bios see this page
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=409741&prodTypeId=12454&objectID=c00220813
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | HP Compaq Presario V2000 Notebook
I am failing to remove the Bios password in Dell Latitude D630
This should be pretty easy to do.
1. Reboot your laptop and select F2 to go into the BIOS settings. You'll need to be quick or it will boot to Windows.
2. Use the --> arrow key to move to the Security page.
3. Arrow down to the Set HDD password and press Enter
4. Enter your current password
5. Select the Enter key twice to enter no password
6. Select the F10 key to save and exit.
Dec 17, 2009 | Dell Latitude D630 PC Notebook
When i insert win xp cd in the driver then nothing happens and it then i press F10 which takes me to BIOS....but after that i just cant do anything..pls help me in step wise manner how should i install...
Make first boot device as your CD ROM by entering in to the BIOS -- > Boot Device Priority. To enter into BIOS either try F2, DEL, F10. then after insert the CD in to the drive and then you can notice this on a black screen " Press any key to boot from the CD" then press Enter or any key and then follow the instructions as suggested on the Setup of Windows XP . Now you can format your laptop.
Oct 21, 2009 | Compaq Presario C700T Notebook
I hav appllied password on presario v 6000. then i remove it,the password was from BIOS, then i removed that password and i have not given any new password but when i restart my laptop it again asked for...
Hi!! Usually HP or Compaq Pavilion Presario passwords are storedin eeprom memories that has to be read or writen to remove / bypass the BIOS password!!! Password generate a hash code that will appear after 3 wrong password attempts and it has a 5 digit decimal format "xxxxx" You can get the hash code by pressing F2 or F10 when you turn on the laptop to enter Bios and then when password prompt appears hit F12 to get the hash code. I got My Pavilion Dv2000 And My Presario V3000 Bios password Unlocked at http://www.laptoprebirth.com They can calculate a master password with the hash code. Hope it helps
Aug 16, 2009 | HP Compaq (188814-001) for Presario 7000...
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
Compaq presario v3000 laptop
www.hp.com
in locate product type
laptop v3000
then click next choose your laptop type ( v3000 )
and options will appear for
software downloads other options are
solve problem
or setup install
please let me know
Feb 17, 2009 | Compaq Creative Sound Blaster PCI 128...
Labtop wont boot...only has a blinking curser
1. Turn on the PC and press the F8 key repeatedly when the first screen appears.
The Windows advanced options menu appears.
2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
3. Select Microsoft Windows Recovery Console .
NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CDs, press the R key to open the Recovery Console.
NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
a. Turn on the PC, and press the F10 key repeatedly at the first screen.
b. At the Recovery screen, click Advanced Options .
c. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
5. At the command prompt, type the following: diskpart
6. Press Enter , do one the following:
  • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
  • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
