Question about Linksys Wireless-G WRT54G Router
Upgraded Cable modem and now cannot connect to internet with wireless modem in-line. Is there some maintenance on the router setup that is needed?
  • Stephen Alip Sep 14, 2010
    who is you internet provider, and what computer can go online directly to the modem
  • 550 Answers
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Sep 15, 2010
I purchased a D-Link Wireless N 150 Router, Dir 600L. I am unable to setup the same. Do I need a Modem also to setup this router or I can setup without a modem?
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Dec 24, 2012 | D-Link DIR-600 Router
I have a viewsonic netbook and want to go on line wireless what do i need apart from a reuter
Requirement to setup a wifi internet connection
1. Modem (Provided by ISP - Internet service provider) 2. Wifi enabled Router (It has to be setup with modem to access internet, ie Modem and router connections using an Ethernet cable) 3. Computer with Wifi LAN adapter ( For receiving wireless signals from Router)
Let me know if you need any assistance in setting up router for wifi access.
Please rate if you like my solution Thanks
Jun 23, 2011 | D-Link Computers & Internet
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
Does a wireless router need to be connected to a phone line?
Hello emanuelav716, Your router does not need to be connected to a phone line. However is does need to be connected to a cable or DSL modem if you want internet access. If you are just looking for a network inside your home or business the router can be setup that way. Please reply with any other questions or rate this solution if you found it helpful. Thanks! Edward
Aug 22, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Every time I connect router I lose internet connectivity - cable When I disconnect router, Internet is fine COmcast Cable blames router ; Cisco blames Comcast - cant get any where with either support team...
modem, that means the modem is working fine.
This router WRT160N hs firmware issues.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with
the cable.
If not then you will need to connect the computer
to the router.
Download the firmware of the router from the
manufacturer's website.
enter the model number. select proper version
number and download the firmware of the router.
Once you download the firmware, you will need to
open the router set up and upgrade the firmware of
the router.
After upgrading the firmware, it is recommended
that you reset and reconfigure the router.
Click Here for more information about router and
networking
Feb 27, 2010 | Linksys WRT160N Wireless Router
Can I setup a cable modem with a router
You can if the router is wireless and you have a wireless card in your computers. If not, then you will have to upgrade the router to a wireless and get wireless cards in the computers or run a cable to the 2nd floor
Oct 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Belkin wireless
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Dec 09, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
24 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
