Question about Venmar CONNAISSEUR 1800 (CCC1830W) Kitchen Hood
THE FAN ONLY WORKS ON THE TOP 2 SPEEDS - Venmar CONNAISSEUR 1800 (CCC1830W) Kitchen Hood
I have 2007 Suzuki XL7. I replaced radiator and fan assembly. Fans do not work. Is there a relay? If so, where is it?
Most fan and Ac relays are located in the under hood fuse and relay box. Adequately marked in owners manual or on plastic cover
Sep 03, 2016 | Suzuki XL7 Cars & Trucks
Blower start up problem
The motor is bad. It is overheating and shutting down on thermal overload. You need a new motor
Jun 24, 2017 | LG LWHD1200FR Wall/Window Air Conditioner
Blower fan low speeds don't work. Can only get the fan to work on position 3 which is too high. What might have happened such that positions 1, and 2 don't work?
it is the blower motor resistor. I do not know off of the top of my head if it is part of the climate control unit or external for your particular vehicle. However the symptoms match.
Feb 21, 2011 | 2001 GMC Yukon XL
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
A/C has quit working on fan speeds 2 thru 4.....it will only work on speed 1 but the fan itself still works on all speeds...it just seems to kick the a/c off on speeds 2 thru 4 and blow hot air ....2001...
You probably have a bad fan switch. I had the same issue and had it diagnosed and replaced. It fixed the problem, but it seems to be coming back less than 2 years later.
Jul 08, 2010 | 2001 Mazda Protege
Need a replacement capacitor
Voltage rating doesn't matter. 250v or 330v will work.
If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
Oct 24, 2009 | Hunter 23852 Classic Original Ceiling Fan
Blower only works on 4 (top speed)
sounds like you need the blower speed resistor...once you put in the new one it will work just fine.......
Sep 19, 2009 | 2000 Ford Focus
GE refridgerator fan speed changes constantly
I will try to answer your question . Your refrigerator had 3 thermistors in the refrig side , and 2 in the freezer side . These thermistors , send resistance messages to the main control board , mounted on the back of the refrigerator . If say #1 thermistor tell the board , I need to be colder , then the board will tell the damper ( small vent in the top of refrig section ) , to open . If the #2 thermistor tells the board , I need to be colder , then the board tells the fan to speed up , to get more air to the refrigerator section . #3 thermistor , works with the turbo cool switch , turning the fan to a high speed also . If the thermistors tell the board , we're all fine , then the fan will slow down , but still circulate to make/keep the freezer colder . If the freezer thermistors say , we're ok also , then the refrigerator will cycle off , until a thermistor asks to be cooler again . The fan works off D C voltage , in which fan speed is regulated (faster or slower) , by the thermistors "talking" to the control board .
Sep 12, 2009 | GE Refrigerators
3 speeds settings - only 1 speed and that is fast
I believe that your fan speed selector is bad.
Jul 02, 2009 | Heating & Cooling
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Venmar CONNAISSEUR 1800 (CCC1830W) Kitchen Hood Logo
16 people viewed this question
Top Venmar Kitchen Ranges Experts
Gil Shultz
ray gallant
Dan Apthorp
Are you a Venmar Kitchen Range Expert? Answer questions, earn points and help others
