Question about Brother DCP-340CW All-In-One InkJet Printer
A máquina Brother DCP-340CW dá um erro no ecrã e diz Não pode imprimir. Já vi se tinha papel encravado e não tem lá nada, e a mensagem é sempre a mesma. Haverá alguma forma de fazer um reset ???
5 Suggested Answers
nicknkell
  • 41 Answers
SOURCE: Brother Model DCP-340CW - Unable to clean
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Disconnect the machine from the power source for several minutes then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
hope this helps please leave rating (vote)
Posted on Jan 26, 2009
komguy
  • 2306 Answers
SOURCE: brother dcp-340cw error 4F (print head), the same as error 41?
It is the printhead, it comes 2 ways, with or without the circuit board, I usually only change the printhead only and it works fine.
Posted on Sep 02, 2009
SpideRaY
  • 687 Answers
SOURCE: DCP-340CW purge counter reset
n the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time you clean the print heads the amount will be between 100 and 130. When this count gets to about 64,000 the error 46 will occur. That's about 510 times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
LOL
Check me out at www.windowstipsclub.co.uk
Posted on Sep 23, 2009
mariolands
  • 2296 Answers
SOURCE: como posso corrigir erro impos
4F message indicates that the printhead is RIP, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Posted on Feb 26, 2011
A minha impressora toda hora esta aparecendo erro 34 papel curto
Verifique se a configuração de tamanho da bandeja, no Menu papel corresponde ao tamanho do papel colocado na bandeja.
Certifique-se que as guias de papel na bandeja est?o na posi??o adequada para o tamanho do papel carregado.
Verifique se o papel est? posicionado corretamente na bandeja. Pressione Menu para abrir o Menu Trabalho e cancelar o trabalho atual.
Para obter assist?ncia adicional entre em contato com o Suporte T?cnico da Lexmark
Jul 08, 2011 | Lexmark X342n All-In-One Laser Printer
O Problema E Que Quando Vou Atualizar Meu PS3 Aparece Occoreu Um Erro Grave Contacte o Apoio Tecnico Para Assistencia E (8002F281) Eu So Fica Nisso Toda Hora Me Ajudem Por Favor !! Grato
Voc? pode tentar baixar a atualiza??o para uma unidade USB e instal?-lo de l?. Se voc? ficar preso em um loop de inicializa??o que voc? pode precisar instalar temporariamente uma unidade de disco r?gido, instalar a atualiza??o a partir daunidade USB e reinstale o velho disco r?gido assim voc? n?o perde as suas informa??es de jogo salvo. Voc? tamb?m pode ligar para o suporte t?cnico da Sony.Se voc? estiver nos Estados Unidos, ligue para 1-800-345-SONY (7669) Portugal:70723 2310 8008 208102 ou em outro lugar. Boa Sorte e desculpe se a tradu??o ?ruim eu falo Ingl?s e eu usei o Google para traduzir.
Mar 08, 2011 | Video Game Consoles & Games
Papel encravado e travou com erro e 01
Você precisa olhar para o caminho do papel e certifique-se de não há nenhum pequenos pedaços de papel bloqueá-lo.
Abra a tampa traseira para verificar lá é nada lá como isso muitas vezes Obtém perdeu.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Gostaria de instalar o software de driver do dispositivo
Já tentou usar o cd do dispositivo ou então no site do fabricante. Se for daqueles tipos Plug and Play ele automaticamente irá pedir o CD na primeira vez que você plugar. Se não aparecer, instale com o CD do dispositivo:
1- Geralmente ao colocar o CD, aparece uma caixinha com passos a serem seguidos do tipo próximo ou next;
2-Você pode ir apertando nos botões proximo(ou next) sem precisar alterar nada pois o padrão já instala certinho, ou se quiser pode alterar algumas coisas durante esse processo de instalação, a sua escolha ;
3- No final aparecerá que o processo foi concluído com sucesso, se não mande a mensagem para cá de erro;
4- Caso conclua com sucesso, verifique se o dispositivo foi instalado ao acessar o gerenciador de dispositivos: Painel de controle-->Gerenciador de Dispositivos;
4.1- Ou então por meio do atalho devmgmt.msc, no executar (acesso por meio das teclas windows+R);
5-Depois tente colocar o dispositivo na máquina.
Estas instruções servem apenas se o sistema for uma das versões do windows.
Mar 01, 2011 | Computers & Internet
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Erro SC550 Aficio 1060
• Web end (requires replacement)
• Web end sensor defective
Note: After replacing the web with a new
one, reset SP1902 turn the value to 0%
Jul 09, 2009 | Quasar SP-3235 32" TV
Hello baixing c2000
This works with my phone. Switch phone off alltogether by holding down the red handset button (the one with a handset icon, second one down on the right) Connect the usb cable to your pc, then to the phone. If all is well the  phone should come on and then the pc recognizes the phone.you should have an extra icon in 'my computer' on the pc.
Sep 21, 2008 | Siemens M56 Earbud Hands Free Headset
Brother DCP-340CW All-In-One InkJet Printer Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
