Question about Vornado Circulating Fan
Need to clean..............how do I get it apart to clean model 280SS Have had this model for quite sometime and it deperately needs a cleaning. THNAK YOU!
  • 12 Answers
There are four clips the hold the grill to the cowl.
Look along the outer edge, on the back.
One clip at 11 o'clock, one at 2 o'clock, one at 4 o'clock, and one at 8 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shuold come off. The clips are just tabs molded into the grill, don't push too agressively, or the tab will break, and the grill will not latch on as well. Check the Vornado website for more information. They used to have a video about cleaning.
Use mild soap and water the clean the blades after removal.
Posted on Mar 12, 2011
Our Miele coffee machine is not grinding the coffee and only delivering water. I have cleaned the brew unit but still no coffee. Any suggestions?
Sounds as if the grinder and or the coffee chute is plugged with grounds, this can happen when using a very fine grind and /or a very oily bean. Sometimes the grinder can be cleared when taken all apart and cleaned with a tooth brush - but this would require a service tech for the most part - have to take quite a bit apart to do this
Oct 30, 2017 | Miele Coffee Makers & Espresso Machines
I have a cordless drill model 6095D. The torque function is always on torque, won't put in screw. I don't need the torque function at all, just straight screw driving, but need to fix some way.
50% of issues like this one are solved by cleaning the mechanism, you have quite old drill so it's a big chance a metal chip went somewhere between the gears, take the drill apart and clean the mechanism first, if this is not the issue you may figure out by taking the drill apart which you need to do in any case. Or take the risk and use brute force. drillselect com
Nov 12, 2016 | Drills
280ss
Check your capacitor.
Jul 17, 2013 | Dryers
I've got some visible(I see it on the pictures and on the digital display) dust (tiny hairs etc) on my lens (actually inside) so it seems I can't get rid of it without taking my cam apart. The dust is then...
If this is a fixed lens camera (you didn't give a model) I'd suggest strongly for you not to attempt to take it apart. Hopefully what you are experiencing is dirt on the outside of the lens. If so turn on the camera huff (breath) on the lens to create a slight amount of moisture and then use a lens cleaning tissue to gently clean the lens.
If as you say this dirt is on the inside then I would suggest getting it cleaned by a camera repair facility. Problem there is a lot of these point and shoot cameras cost more to clean and fix then it does to just go get another one.
Next thing if the inside is dirty they you must have a lot of lint in your pockets or you have been using this camera in a dusty environment. For carrying it would be best in an actual camera case rather then an open pocket and for dusty condition I've used shallow water camera bags and I've also used ZipLock bags while photographing a waterfall.
Apr 12, 2011 | Panasonic Cameras
HAVE A 20" SYLVANIA TV MODEL 6420FMG-REMOTE
Take it apart and wipe everything clean....I spilled soda on my remote and the same thing happened sometimes I'd push one button and I'd turn off the TV or go to the meny when I wanted to chabge the channel... A couple of screws and it will come right apart
Feb 18, 2011 | Sylvania Televison & Video
Hi I have a Lofra Maxima Model no: MXD96AMFEP and need the Oven Selector Switch and Oven Door Hinges - can anyone help please am deperate!
Hi Gemma, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Jan 18, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Gauges quit working...they work when they want to
I have the same car... And mine was doing the same theng.. and a buddy of mine he had one and his did the same thing...It is the connections... they go bad just need to be replaced and should solve the problem it did for both of us
Apr 14, 2009 | 1999 Dodge Neon
The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
Jan 19, 2009 | Vornado VH2 Compact Heater
Cant get rainbow shampooer to work
use the suction port for the vac hose
the water hose hooks to your kitchen faucet
Nov 11, 2008 | Rainbow E series Canister Wet/Dry Vacuum
My unit won't let me type in the city of Depere, WI
you may need to update the map on your unit.
First I would try this
It should have recognized where you are when turned on.
go back to the store or any store and see if the same unit in that store recognises the location, if yes yours is defective, exchange.
If no ( must be a really small rural town) check the manufacturer wesite to update the map for your town.
Aug 12, 2008 | Garmin Nuvi 660 GPS Receiver
Vornado Circulating Fan Logo
1,277 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
