Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
The dishwasher will go through wash cycle then turnoff. i have to manually press cancel drain to drain soap and water then manually press rinse to rinse dishes. it is about 10 years old. is there anyway to fix it?
  • 901 Answers
This must be mechanical timer model. Check the timer cam movement.
If possible replace the timer as a whole assy. Note down the wire colors while doing so.
Posted on Sep 15, 2010
I have an older GE dishwasher Model # GMB921HB119. The machine operates normally till it reaches what I believe is the final rince cycle and stops. The timer continues to advance, reaching the drying cycle...
Is this machine new to you or have you had it long enough to see it work properly?
If it used to work as it should then you know that there is probably a problem other than your water or soap. If you have whopping lime in your water then the problem could be in a water treatment system (softener, RO system, etc) Is there a screen and is it not plugged when you clean it? Does the machine drain the wash water properly? Does it spray in the rinse cycle?
If the screen is not plugged then it should be able to drain the wash water. If it's draining the wash water then you should get a good rinse if you're not using too much soap. If it's not draining the wash or spraying the rinse then I'd suspect the timer. If it's not draining I'd suspect a plugged screen, a solenoid valve or the timer. If it's not spraying the rinse then it's just about got to be the timer.
lp
Dec 26, 2010 | Maytag Dishwasher
Frigidaire dishwasher won't end cycle - will run on and on for hours. Sometimes it cycles through, usually it just endlessly washes and rinses. I have to CANCEL the cycle, which causes the dishwasher to...
I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
Apr 07, 2010 | Frigidaire 24 in. FDBB540 Built-in...
Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
No Water in. Will not change wash cycles
There was soap particles caught under the float valve. Thanks.
Jim
Mar 03, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher does not complete cycle
The solution i'm going to give you might sound weird but it should work. The drain hose should have a curve of about 36 inches up and then down to the drain. This avoids the water to drain on its own, the water has to be forced out by the washing machine. hope it helps.
Jan 19, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water in bottom, and it wont turn on
my neighbor fix it, don't know how.
Jan 09, 2009 | Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
66 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
