Question about HP Pavilion ze4125 Notebook
Headphone Speaker Jack Needs Replacement
Hi, Does anyone know how to open my HP Pavilion ze4125 laptop to replace or repair the headphone jack. I plug in my ear phones and have to jiggle the male connector to hear sound and/or when typing I'll hear sound out of one speaker only. Maybe just a quick solder? Any ideas would be appreciated. Thanks!! Bruce
    Scholar:
  • 143 Answers
Hey Surfit, use this link and then download the service manual. This should be all you need!! I checked it and it looks good to go! Let me know... and if so, rate my answer!
Posted on May 16, 2008
  • Eric Smale
    Eric Smale May 16, 2008
    Oops!! Sorry, here is the link! What a dope! I'm tired, please forgive me!
    http://h10025.www1.hp.com/ewfrf/wc/manua...
    And TJ, this laptop is about 4-5 years old. I don't think it would be in warranty unless and extended warranty was purchased. You are right to try different headphones before laboring through disassembly of a laptop.
    Scholar:
  • 67 Answers
That honestly sounds more like a headphone wire problem than anything else. If you have another headset, headphones or speaker system that you can hook up, I would test it on those to try to rule that out as a problem.
If that isnt it, I can try to find the disassembly instructions for your laptop. (Unless your warranty is still good, in which case I would tell you to send it in and get it fixed professionally.)
How do i fix hp pavilion dv 6 sound problem
I would check the headphone socket is not damaged. If there is a faulty contact, the headphones will still work but the speakers won't.
Feb 16, 2016 | HP Pavilion DV6700T Notebook PC
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
My headphone jack does not work, sound still comes out from the speaker when i plug head phone. please what should i do?
it shows that the headphone may gone bad, or the jack of your pc needs repair, check your headphone to some other computer if it ok then go for repair the jack from some qualified technician
Jan 11, 2013 | Computers & Internet
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
Headphone audio doesn't work when pluged into headphone jack but will work if pluged into speaker jack
since speaker works nothing should stop the headphone it is likely that the headphone is faulty.try another headphone
Mar 16, 2011 | HP Pavilion DV8225NR Notebook
I reinstalled my operating system after that my speaker disn't work
Sound is not working. Headphones would work just fine but the built-in speakers stopped working. try to update and reinstall the drivers. The speakers would sometimes work for a second when removed the headphone jack. sometimes it was a short in the jack connection or just a bad connector in the jack. Sooo, just plugg in the headphone jack a bunch of times and after about 20 seconds the speakers will work just fine.
Dec 14, 2010 | HP Pavilion dv6000z Notebook
I have an Acer Aspire Notebook. When I plug headphones into the audio jack there is no sound, however, the sound works fine from the notebook speakers. Can anyone help me?
Hi, May I know if have tried alternate headphones and if they are the same?Does the headphone work when wiggled within the port if yes then the issue is with the headphone jack being loose and you would need to send the computer for a repair if covered by the manufacturers warranty as the headphone jack needs to be replaced. Thank you for your time.
Nov 23, 2010 | Acer Aspire One A150-1006 Notebook
Headphone jack needs repairing
u will need to get ur headphone jack replaced as it it the only sound out u have, secondly, u can go to anyone who repairs motherboard and get it done. its not neccesary only from the company because u will be charged more there, but mind u they give warranty for their work. so ur choice
good day
Jun 02, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Speaker problem
The headset jack is broken and needs to be replaced.
Nov 04, 2008 | Panasonic RR-830 Desktop Cassette...
HP Pavilion ze4125 Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
