Question about Rockford Fosgate Punch 201S Car Audio Amplifier
The amp was getting hot and shuting off and now it stays on but no sound and it dosnt get hot any more
  • 30 Answers
First check the ground. it should be directly to the frame and bare clean metal...no paint! then check the ohm load from the subs its probabily too low causing it to go into protect. if there a safeload for the amp back your gains down...never go below 3/4 of the way electronics do not proform well when they get hot!
Posted on Sep 15, 2010
Issue is the sound only stays on for two seconds and then silence for two seconds and then again and again.
Do you have an amp or it's this running through an amp? If so sounds like it's a thermal issue to hot. If it's not hot check to see if it's got a good connection on power or ground. I've seen this happen where the radio turns it on for a couple seconds the sees an issue and shuts back down. With or with out amp, could also be blown speaker shorting out. Can unplug one speaker at a time till radio stays on or check each speaker with an ohm meter, should read 4ohm with no current going into speaker. I've seen that happen also with bad RCA cables going to amp. If is an amp you can check the light on the amp to see if going on and off, unhook Rca cables then check to see if amp stays on. Hope that helps
Mar 05, 2016 | Audio Players & Recorders
Amp just stoped working but power light stays on
It sounds like a component failure inside the amp. When it gets hot, the component fails. Repairing this type of failure requires skill and experience. I'd seek the help of a professional who can actually look at the amp.
Jan 20, 2014 | Car Audio & Video
Power amp 2600 getting hot shuting off or cracking noice on one side
sounds like your cooling fans may not be working properly. Feel the bottom of the amp to check for forced air from the fans. Amps will over heat very quickly once the fans burn out..Hope this helps shannon
Mar 07, 2012 | Music
Onga Pantera ppp750 3 years old - thinking electrical problem? Pump is switching itself off randomly, dosnt seem to be getting hot (cool to touch) did hear a clicking sound before we manually turn it back...
If it is equiped with a starting relay,the relay is the problem,replace it with the same and better replacement.The contacts seems to loose it through wear and tear.
Dec 05, 2010 | Plumbing
The lights inside the car won't shut off when I'm getting in & out of the car.
theres three settings to the light one is off one is stay on one is go off after shuting doors
Nov 29, 2010 | 1999 Oldsmobile Intrigue
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
Oven glow plug on but oven wont light , dosnt get hot , top burners work fine. broiler also dosnt work . oven about 13 yrs old
if ignitor glows and the burner does not fire within 30-60 seconds it is weak (not drawing 3.5 amps or higher) and should be replaced. Hope this helps,please rate my solution
Jun 26, 2009 | GE JGRP17 Gas Single Oven
Cant turn up the music witout the amp shuting off
look insayd tz100 is dead replaeis end troae egayn
Mar 29, 2007 | Alpine MRP-M350 Car Audio Amplifier
Rockford Fosgate Punch 201S Car Audio Amplifier Logo
83 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
