Question about BenQ FP737S-D 17" LCD Monitor
Still no display
The voltage output of PQ3RD23 is 3.3V. i've tested all four c5707 transistor. One of them is shorted so i replaced it with a new one. Still no display on my LCD. what could be the problem?
    Scholar:
  • 143 Answers
Is there a diode on the other side of the transistor? That could have gone as well (if my electronics repair hasn't failed me yet!!) That is just a stab in the dark. Sorry I couldn't be more help, but it has been quite a few years (15 at least!).
Posted on May 16, 2008
My AV-502A main amplifier fuse was blown,I checked the power transistors and found 2 shorted,C5198.I replaced it with new one, but the fuses still blown up, including the new transistors.
There are several reasons. If you find one shorted transistor in a push-pull stage you should always replace both. One might be faulty but not shorted, but when in operation it does the other one in. You might have also missed another shorted part such as a diode or voltage regulator. Hunt around looking at the circuit of the confirmed shorted parts and test or replace anything off that circuit.
Finally check your speakers and wiring to them. Shorted output transistors have generally two ways of going like that. Wires touching each other or bad speakers, or having it too loud!
Feb 02, 2016 | Audio Players & Recorders
My monitor was just blinking folowing the thunderstom some days back and I tried to replace some 4 capacitors coded C5707,and it comes on but abnormal display and then the replaced transistors burn out...
At this point you may be better off to replace the whole board, the four C5707 are transistors, not capacitor. You need to make sure that there are no cold solder joints around inverter transformers lead, check the tuning caps in the inverter output sections.
Replacement board: http://www.lcdrepair.us
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 12, 2010 | Dell E173FP 17" LCD Monitor
Monitor dark but can see image in background
if u have warrenty then immediately contact u r dell service.
he check the problem and replace new one.
i also suffer same problem.
Jul 28, 2008 | Dell E173FP 17" LCD Monitor
Found them
If you are referring to the C5707 inverter driver transistors, you can test them in circuit with an ohmmeter. Usually one pair will show shorted although only one may be actually shorted. Normal procedure is to replace the pair that shows in circuit short. If you do not resolder the transformer connections your transistors will short again.
Monitor Mike
May 30, 2008 | BenQ FP737S-D 17" LCD Monitor
Please help me.
checked the horizontal output,a big transistor near the flyback trnsformer, if it is shorted replace it,,,,
Feb 13, 2008 | Sampo AlphaScan 411 Monitor
LED's blinking, no video
Your C5707 transistors in the monitor have failed. Suggest replacing all four with the Sanyo C5707 transistor. A common problem.
Dec 10, 2007 | Dell E173FP 17" LCD Monitor
Dell E172FPb 17" LCD Monitor Problem
Your inverter power supply has gone bad. You will need to replace the whole board or replace the the 2sc5707 transistors in the inverter area. Check out this link for installation videos and how to for that model
http://www.lcdrepair.us/Installation.html
They also sell the whole board as well as repair kits
Oct 27, 2007 | Dell E153FP 15" LCD Monitor
RCA F27669 27"
The F27669 uses the CTC203 series chassis. The most common cause of that symptom is a shorted horizontal output transistor, caused by a cracked solder joint on a small coil connected to that transistor's base. When this happens, the main B+ supply is shorted to ground so the power supply squeels. Every once in a while I also see the horizontal output transistor shorted due to a shorted flyback (high voltage) transformer. A good tech will replace the horizontal output transistor, resolder the coil and drive transformer, test the flyback (replacing it if necessary) and your set will be back to perfect.
Aug 08, 2007 | RCA 27V570T 27" TV
BENQ FP731s Monitor Problem white blank screen
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
May 06, 2007 | BenQ FP731 17" LCD Monitor
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
BenQ FP737S-D 17" LCD Monitor Logo
69 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
