Question about Eureka WhirlWind 4381 Upright Vacuum
How do you change the belt on the eureka 3281az ? can,t get the plate off the vacuum to see even where the belt would go ? thanks!!
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: belt change for eureka capture
There 2 or 3 screw on the top cover to remove, then it comes off. Then you can get to the belt, inspect the brush roll while you have it out, make sure the ends move freely.
Posted on Jun 22, 2008
  • 43 Answers
SOURCE: how to change belt on eureka vacuum 2996
The information you're looking for can be found on page 8 of the manual via this link: http://www.eureka.com/service/manuals/80244.pdf
Posted on May 06, 2009
SOURCE: broken belt
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
Posted on Aug 18, 2010
How do i change the vacum belt on my eureka mega boss
Turn the unit upside down and remove the screws holding the bottom plate on. After you do that, you will be able to access the belt.
Jul 01, 2011 | Eureka Mega Boss 4460DT Vacuum
Eureka Fantom Thunder 12V/older model Need instructions on how to change belt and headlights.I could only find 1 screw on the bottom plate none on top plate. Thanks N J
there are two screws on the Fantom Thunder (It was not made by Eureka though) on the back of the unit just above the rear wheels. Remove these two screws and the top cover can be removed to get to the brushroll, belt and headlights. I believe the light bulbs in this unit are 12 Volt, not 110 volt.
Jul 18, 2010 | Vacuums
Broken belt i need a replacement belt for eureka altima bagless vacuum
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
The belt broke on my vacuum, how do i change it. the vacuum is a eureka model number 3041
Remove the base plate. It is held with screws accessible from under the unit.
Inside you will see the beater bar and the belt.
Remove the beater bar. This is self explanatory once you see inside the power head.
Remove the old belt.
Find a replacement from your local dealer or online.
Replacement is the reverse of removal.
This is a simple job you only need a screwdriver.
Good luck, please rate this answer. Thanks.
Mar 27, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
Jan 20, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
I have a Eureka Bravo! 7.0 vaccum cleaner, how do I change the belt
Turn the vac over so the brush is facing up.. There is a cover plate that surrounds the brush.. Take the screws out and remove the cover plate.. Pull up on the side of the brush that the belt is on.. Replace the belt.. The belt goes around the metal shaft and the brush.. Push the brush back in place.. It might be a bit tough going in because the belt causes some tension.. Put the cover plate and screws back in..
Good luck ! Please don’t forget to rate well ;o)
Aug 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Change belt on a eureka
With the vacuum unplugged, turn the machine beater side uo. On the plate that surrounds the beater bar, look for release tabs to open the plate. Flip them and set the plate to the side. The beater bar rides in sockets. Remove the bar, install the new belt around the motor shaft, then work the beater back into the sockets. Replace the plate. Test your work by rotating the beater bar by hand, making sure that it is reinstalled correctly.
Best Regards, --WoobieDog--
Jul 10, 2009 | Eureka Vacuums
How to change belt on Eureka maxima 4700a
hey i had the same problem with mine, (standing over it and looking straight down) there should be two screws on the top of the yellow cover, one on each side, take those out and the yellow cover should easliy pop off. if the white ink is off the belt or the belt isnt tight than replace, once off just pop the wheel brush (which has the belt around it) up out of its socket and take off of the belt from the wheel brush and motor's metal pole, then put on the new one just like the old one was. let me know how it works out, redsox_belcher@yahoo.com
Jan 17, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka the boss upright bagless vacuum. how do i open it to get to the belt area? the brush seems stuck. it wont move
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=801547
Generic problem for all Vacuums
Posted by sweet0nes on July 18, 2008
Eureka the boss upright bagless vacuum. How do I open it to get to the belt area? The brush seems stuck. It won’t move.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 18, 2008 | Vacuums
Eureka WhirlWind 4381 Upright Vacuum Logo
562 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
