How to connect a router forwireless laptop - Computers & Internet
Can I use USB Cable direct to laptop from modem? Ethernet cable from modem is connected to router which is connected to desk top PC. OR should I connect a ethernet cable from router to laptop? Type of...
Hi Friend, It depends that whether your router is wireless or wired. If it is a wireless router then there is no need to connect the laptop with the cable, you can use the laptop wirelessly If it is a wired router and as you said that the Desktop is already connected to the router with the cable so in that case you have to get another ethernet cable and can connect it from the router to your laptop
Dec 08, 2010 | Computers & Internet
Laptop running 0n win 7 wont connect to router
1. you will have to designate the laptop or allow it to connect by entering it into the 3com router.
2. try connecting to the router via ethernet cord (that is connecting with a physical straight through cord) that came with the router.
If connected with this then you will have to go into the router via the IP set 192.168..0.1 depending on the router ip for loging in.
2. Go to the "wireless setup" and enter your MAC address for the laptop in the permissions list in the router. Instructions on how to do this is at the manufacturers site. Step by step.
3. Do the following step if instructions not found.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 19, 2010 | 3Com OfficeConnect Router
My Dell laptop does not connect easily to d-link WBR 2310 router
2 wireless laptops are connecting. that means the router must be working properly. Only 1 laptop is not connecting.
Try to change the wireless channel on the router.
For this you will need to open the set up page of the router.
Is there any computer connected to the router ? If not then you will need to connect the computer to the router and open the set up page. Under wireless settings try to change the wireless channel on the router and see if that works.
Apr 16, 2010 | D-Link Computers & Internet
How to get the router to work.... i have a desktop and a laptop and the desktop has internet .....but how do i get the laptop connected to the internet using the router
Connect your internet connection to the port on the router
then connect your laptop and desktop to the router.
if you have a user name and password enter these in the router settings
everything should work
Oct 07, 2009 | D-Link AirPlus Xtreme G DI-624S Wireless...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Connect a laptop to the router
hi ,
i went through the issue that u nr facing
well the only solution is to connect modem to router and then connect router to ethernet port of laptop
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Can't connect to laptop
that your router have a Dynamic setting?
Mar 11, 2008 | Zoom X6 Adsl Modem/router Rohs...
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
