Question about Microsoft Xbox 360 Console
Video gone, audio still works - Microsoft Xbox 360 Console
  • 4,102 Answers
Hi the problem you are having will lead to the red ring of death, you get the rrod when the gpu and cpu chip have over heated, as you get the sound and no picture this says that the gpu is over heating and needs fixing.
you can try the following
1 switch the xbox off and leave it off for at least an hour
2 check all air vents are free from dust
3 make sure your not using the xbox on carpet or on top of anything like dvd or sky box
any of the above will cause it to over heat so make sure the xbox is not in a confined spaced and not on top of anything else
remove the leads from back of xbox and remove hard drive, plug all the leads back in making sure the leads are pushed in properly in the xbox and back of telly, then if you still have the problem try and borrow a friends video lead to try on your xbox.
if it still dont work then this suggests it has over heated and the damage is done so check if you have any warranty before you do anything with it, then if you have warranty take it back and get it exchanged or if your warranty it out you need to get the gpu and cpu heat sink changed and the x clamps removed and getting this done should get it working.
but you need to know that say out of every 10 i do work on only 2 wont work and would be classed as scrap, i repair these for about 25 quid plus parts which is about a fiver so your looking at roughly them prices to get it fixed, i work on the basis that if i dont fix the problem i wont charge for the work i just charge for the parts used.
let me know if you need further assistance
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 15, 2010
Why there's no onscreen display on my yamaha receiver, the power is on?
Open the YMHA chaik cable for display and chaik may display gone may inside led gone internal problem some fuse r ic chaik
Aug 31, 2014 | Yamaha RX-V467 Audio video AV Receiver for...
Video and audio turn off and back on about every 10 seconds.
Check audio/video cable and replace with a known good one it may be a loose connection on the cable or the cable connection port on the back of the console. If that doesn't work then one of the boards in the console may have gone bad.
Jan 15, 2013 | Video Game Consoles & Games
When we turn to the tv to "av" we usually get signal for WII, but now it says "no signal"
Make sure your video connections are correct and make sure any external video selectors are set to the correct input. If the wii is connected directly to the AV input in the TV then check your resolution settings on the TV if possible. Try a known good wii audio/video cable to see if it has gone bad. If it still doesn't work after that then the audio video port on the back of the wii may have gone bad or the wii motherboard may have gone bad.
Jan 15, 2013 | Nintendo Wii Console
Shorted binding post
The front right channel audio output semiconductor will need to be replaced, and i recommend a qualified technician because this will be a complex repair.
Mar 19, 2012 | Onkyo TX-DS494 Receiver
Sounds and video has gone
You need to find and install the audio and video drivers for your laptop.
Usually laptops come with a Recovery CD, and all the drivers should be included in it.
If not, just visit the manufacturer web site, look for the correct drivers, download and install.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | Intel Frontier Design Dakota 24-Bit PCI...
No audio in my goodmans LD1928w television
I would first try to determine if the problem is in the audio circuit or in the IF circuit. First you will need an RF signal generator with audio and video modulation this will allow you to inject audio into the set and allow you to track the signal with an oscilloscope. I would make the suggestion by your post that the audio circuit might be defective. However troubleshooting is the best bet. I would suggest that you have a qualified TV technician check the set out.
I hope this helps
Thank you,
Aug 21, 2008 | Televison & Video
Have video but no audio on lg 42 lcd, simplink not working
then check for the audio connector pins sir
they must have gone faulty
Aug 15, 2008 | LG Televison & Video
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
