Question about Maytag Neptune MDE4000 Electric Dryer
The dryer just stopped working, like it is not getting power. I checked the breaker and it was not tripprd. I flipped it on and off. Is there a reset or a board that went out?
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
Dryer stopped working. Not spinning or anything
You will be needing someone with an electric meter, (an ohm meter or a multi-meter) to begin testing to find out if it is the dryer or the power source.
The one thing you could do is check the fuse panel or the circuit breaker box to see if a circuit breaker popped or a fuse blew.
The circuit breaker can be reset by flipping the handle a few times, a fuse would need replacement.
Other than that, an electric meter will tell if the plug socket is live or dead, and then the machine needs be taken apart to see which part has failed. Usually a fuse or a thermo-switch has popped inside the machine.
God bless your efforts.
Sep 08, 2015 | Avanti D110 Electric Portable Dryer
The drum is turning but not heating up why?
It could be a bad heater, thermal fuse or if an electric dryer possibly one leg of your power is tripped and needs resetting at the circuit breaker on the house. Try flipping the ganged power breaker both off real hard and flipping them back on real hard and see if that restores the power to the dryer. If a gas dryer then the igniter or flame sensor could be bad.
Apr 28, 2015 | Dryers
My dry quite working after my was work in electric box he was flipping power on and off
Your dryer is a 220 appliance and should be on a circuit all by itself. Are the items in your circuit box labeled (Lights? kitchen, etc.) One should be labeled "dryer". If you cannot locate one that is labeled for your dryer, Check out the position of the circuit breakers. If the dryer breaker is turned off it will be in the oppoite postion of the others.Caution: DO NOT do what he did and begin flipping breakers! If your dryer breaker is in the off position,is you should be able to flip it back on. Before you do this, have the dryer turned off.
If this does not work, unplug your dryer and leave it unplugged for 5 minutes or so, so that the dryers' operating system can reset itself. Then try turning it back on.
Dec 16, 2010 | Maytag Dryers
We flipped the breakers in our fuse box to do some wiring, when we flipped breakers back--our electric dryer will not start, but the light is on inside the dryer when I open the door
Hello- I would check the dryer outlet and confirm you are getting 220V. As well, flip the dryer breaker on an off again (it should be a double style breaker, 2 singles linked) sometimes they are sticky. Let me know if it still doesn't work. Best regards.
Sep 27, 2010 | Maytag Dryers
Dryer wont turn on. Breaker in breaker box is fine. No light inside dryer. What's wrong?
Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work now? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Whirlpool LEB6300 Electric Dryer
Dryer not turning on
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Estate TEDX640JQ Electric Dryer
Where are home fuses located on the kenmore dryer?
If you were told to check the home fuses its the circuit breaker for the house. If the house is older it may have a small circuit breaker just for the dryer. Otherwise open the circuit breaker for the house and look for the dryer fuse. Usually 2 20amp breakers together. Flip it off and push towards off a little more to reset than flip back on.
Jul 30, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
No power to heater minimax 400 pentair
turn all breaker off that are related to the pool equipment even the one at the main panel. if not check for power 220 v at the timer if power check the wires if not power the breaker may need to be replace
Sep 07, 2009 | Pentair 400k Minimax Ch Ng Mv Heater
Maytag Neptune MDE4000 Electric Dryer Logo
44 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
