Question about Xerox WorkCentre 4150 Black and White Copier
Como resolver o ERRO U4-2 , ( PLEASE REBOOT PRINTER 010-312) EM MULTIFUNCIONAL XEROX WORKCENTRE 423 .
4 Suggested Answers
SOURCE: clear u4-2
Check the manual or the internet for the code
Posted on May 25, 2007
goodgold
  • 389 Answers
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Posted on Sep 13, 2009
lbrown1806
  • 488 Answers
SOURCE: I need a list of erro codes and definations for
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Posted on Jan 16, 2011
Printing error on xerox 7345 network printer
Dear download the driver and re install your problem wil;l be get resolved make sure you have the pst script function enabled, if not please install pcl 6 driver.
May 15, 2011 | Xerox WorkCentre Pro 423 Copier
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
I have a xerox 423 with au3-5 error.whats up?
i have a xerox 423 with u2-3 error code whats that
Dec 07, 2010 | Xerox WorkCentre Pro 423 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
What causes j 7 error copde in xerox workcentre Pro 423 and how is it cleared
by replacing the drum unit or replacing the crum the code j7 will be cleared
Aug 13, 2009 | Xerox WorkCentre Pro 423 Copier
Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Jul 01, 2009 | Xerox WorkCentre Pro 423 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox 423, hard disk error
Hi
Replace Hard disk and try, It will work.
Dileep
Nov 05, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox WorkCentre 4150 Black and White Copier Logo
240 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
