I changed my hard drive cos it was bad.the new one i got is working fine but no sound comes from anything i play on my pc, pls need assistance now
  • 61 Answers
Go to start, control panel, sounds & audio devices. Make sure that the mute box is unchecked. If that is good, then you may have to download the audio driver for your device again. If you have the sound device integrated on the motherboard, you should have a driver disk for it for the motherboard. If not, check online for your motherboard and download the driver. If you have a sound card, once again, download the driver from the disk or if no disk, go to site of the model of the card and download the driver. Hope this helps!
Posted on Sep 14, 2010
No sound device, just multimedia device after adding a new hard drive and Windows XP reinstall.
Are you booting in from one of 2 hard drives at start-up .. ie. do you have a dual-boot system?
If your sound works fine when using the original hard drive but not when you boot from the slave, then it sounds like a driver problem -in the slave. You'll need to download the sound drivers for XP/Slave.
I can't think of any reason why your computer should beep after you have opened and closed the case. I don't think it is anything to do with the case. It's more likely that there's a bad connection or fault (maybe you have the slave and master on the wrong cable) - or badly fitted RAM.
Count the error beeps - there is a pattern of long and short beeps. You can find a list of their meanings here:
http://www.pcstats.com/articleview.cfm?articleID=1223
Though having said that, I would hazard a guess that you've got the master/slave configuration wrong. If you have both hard drives on one cable (ide) the MASTER drive should be at the end of the cable.
Remember there's a primary master (c) and a secondary master - your dvd drive. A 2nd hard drive would be set up to be the primary SLAVE. You cannot have 2 'master' drives on the same cable or bus. That would cause an error beep ...
Nov 28, 2013 | Packard Bell iMedia Computers & Internet
Why is the karaoke music from my external hard
Playing through the USB port can cause all sorts of "problems" also ensure NO other software is competing for the CPU time. It is always best to play work on use, anything or file, from the actual hard drive. simply copy the files to the HD, and use them from there Also more RAM is always beneficial Also make sure you have the most up-to-date Codecs installed too.
Mar 16, 2010 | Toshiba Satellite L45-S7409 Notebook PC
Cannot add anything to my external hard drive
re-hobrax
also make sure you are in administrator account to make changes
Feb 18, 2010 | Iomega (33090) 250 GB Hard Drive
Need to bypass HDD password. my laptop has prompted me to enter a hard drive password, which i didnt set, so can u please assist? Thank you
As far as I know when u try and install new hard drive it will ask for the hdd pswrd ... so do check before u do anything stupid once I have messed up two of the hard dives new and old one too ...
Default pswrd may be 0000 so pls check and do research bfore u do anyting stupid ok
Thanks
Jan 28, 2010 | Samsung X05 Notebook
Hi i have an maxtor one touch 4 it was working fine into one day i hook it up and it didnt read not i get a flashing white like on my hard drive
There are a few reasons this would happen, The options are a bad USB cable, a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians test it with a new USB cable, if it works buy the new cable. If that also fails to work have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Nov 03, 2009 | Maxtor Hard Drive
Blocking zero
Toll restrictions (TRS) comes from the phone SYSTEM, not the set, and it depends on what system you have. Your system should have more than one manual. In the FEATURES guide, it will tell you how to set up TRS and the programming manual will tell you how to do it.
Simply, a phone has a Class of Service COS and each COS had an ALLOW and DENY table. If you put "0" in the deny table for COS 2 and change the COS of an extension to 2, it will be restricted. I'm not sure you can restrict 0x and allow 0 as the screening will stop after the first digit passes. Here in the U.S., we restrict 0 and forget about it as the operators can be talked into placing the call as operator assist.
If you need specific help, please post the model of your system and I might be able to give you better information. I have a link to another site if your model is TA-824, but you should be able to work out the programming with the right manuals.
Carl
Feb 02, 2009 | Panasonic KX-T7730 Corded Phone
I have a 2.5" seagate 100GB that is enclosed in a aluminum usb HDD case. The connector is a USB Y cable. It is suppose to be compatible with USB 2.0 and USB 1.1. I am running windows xp home on my pc and...
pls remove the hard disk from enclouser and plug direct to sata port and check if run well.
if not pls check with bios detection, if enclouser is good and hard is bad, there was no detection with usb port.
Apr 03, 2017 | Fanner Computers & Internet
Hyundai Tucson 2.0L Year 2006
Sounds like bad CV (constant velocity) joints in the front half shafts.
They make the most noise at a full wheel cut.
Aug 06, 2008 | 2006 Hyundai Tucson
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
