Question about Dell Dimension 5100 (D51L1) PC Desktop
High Hard Drive Temperature
I have a Dimension 5100 with it's original Western Digital 160gb hard drive. The literature says the operating temperature up to 30 degrees Celsius. Mine is running at 46 degrees. I've heard high temperatures shorten the life of any drive.
I've seen the hard drive coolers and fans around but since Dell has the blue "snap in" hard drive system (and I've just put in a second hard drive), does any have any advise on what fan or cooler would fit/work in my Dell. Thanks
  • cosmo_aka May 23, 2008
    I looked at the hard drive cooler you suggested and it looked way to big for the space I have. The hardrives are set very close (see manual) and just a small amount of space underneath the bottom. Apparently with any of these coolers a good bit of modification is necessary.
    Just trying to find the easiest thing to install into Dells strange configuration. Looking at maybe using a case fan or cpu fan (if I can find one small enough!) to try mounting underneath the 2nd drive.
    With the computer case open I aimed an old desk fan at the hard drives and it lowered the temps considerably. Maybe just drilling some tidy holes in the side of the case and using this simple rig is the answer? :)
    Thanks for your reply. Any other ideas are welcome
    Cos'
  • brjohn1 Jan 23, 2009
    Running at 50-56C.
    It didn't used to run this hot, why now, with no environmental changes to speak off and recently cleaned all the events out?
  • 67 Answers
You can check zalman's homesite. http://www.zalman.co.kr/eng/main.asp
I can recommend them to you.
CS.
Posted on May 16, 2008
HW DO I PERFORM A WD SELF TEST
Hard drive testing of the WD is done with operating system tools that are in the system tools drop down menu. to test the hard drive in Windows follow the instructions at this link
Aug 24, 2012 | Western Digital WD WD1600AAJB 20PK CAVIAR...
The WD hard disk 160GB is not recognized after plugging into USB
It is very possible that your BIOS will not support a large hard drive. Without more information on your system it will be hard to diagnose your problem.
Oct 06, 2009 | Western Digital Elements powered by WD 320...
I want to make an internal western digital 160GB drive from my imac g5 20" into an external drive and need to figure out what enclosure and cables i will need
You need the following
http://cgi.ebay.co.uk/External-USB-2-0-2-5-SATA-HDD-Hard-Disk-Case-Enclosure_W0QQitemZ320419271720QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item4a9a7a1428&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/3-5-IDE-Aluminum-Hard-Drive-HDD-HD-External-Enclosure_W0QQitemZ400070866376QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5d2614f5c8&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/New-3-5-USB-2-0-External-Hard-Drive-Case-HDD-Enclosure_W0QQitemZ170377549189QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item27ab4b1585&_trksid=p3286.c0.m14
Please note the links are an example only.
Sep 02, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Directory corrupted - unreadable.
try to run chkdsk (checkdisk) ---- chkdsk c: /f /r
also probably you need recovery software (easy recovery professional)
Jun 29, 2009 | Western Digital Passport 320GB External...
Drivelock hdd bay password
Hi
This drive may have been used before and may have had a password set on it. If it is new take it back and exchange it
Cheers
David
Jun 21, 2009 | Western Digital Scorpio 160GB Internal...
I have a western digital external hard drive and im using the getbackdata software to try and recover about a 160gb of data. eventually the blue light goes out on the hard drive and software...
Your hard drive might be failing. Or it is possible that GetBackData might have a bug. Have you tried the latest version of the software? Try a different software to see if that helps.There are even some freeware data recovery softward utilities out there. Google for them.
May 19, 2009 | Western Digital Passport 320GB External...
High Speed USB controller
You can purchase a high-speed PCI usb card. These are generally inexpensive and can be found at best-buy or perhaps walmart.
Feb 01, 2009 | Western Digital Passport 160GB External...
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
May 30, 2008 | Acer Aspire 5100 Notebook
Installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Apr 07, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Dell Dimension 5100 (D51L1) PC Desktop Logo
64 people viewed this question
Alun Cox
