Question about Philips SA5125/37 MP3 Player
Not charging or turning on
My device is not turning on or charging, it wont reset and device manager cannot detect it i have tried the vol+ when i connect it but it doesnt do anything at all can you help me?
  • 2 more comments
  • Anonymous May 18, 2008
    my device is not turning on or charging, it wont reset and device manager cannot detect it i have tried the vol+ when i connect it but it doesnt do anything at all can you help me?
  • maxamed May 20, 2008
    you turn it on than it said correption need to repair after that it says all contents has been clear, then it freezes
  • Anonymous Jul 25, 2008
    wont turn on or not charging
  • elmo24 Aug 12, 2008
    my mp3 wont charge or turn on when it turns on it freezes
Ok try the soft reset button with a safety pin... i ended up doing this... it doesnt erase ur songs
Posted on May 23, 2008
  • 8,596 Answers
Firmware upgrade is the only thing that fixes the memory corruption issue
Posted on May 22, 2008
My phone wont turn on it gets freezed on andrid robot
have you tried factory reset by holding power on and vol down buttons most android phones do this some are power and vol dwn or vol up or both keep trying to see which one yours is also some times you may have to remove sim and sd card not all the time but in some cases then just go to factory reset using vol buttons to move up an dwn hope this helps
Oct 06, 2014 | ZTE Avid 4G Black Smartphone - MetroPCS...
Galaxy tab 2 10.1 does'nt show thw level ef charge
Try Resetting the Device Cache Partition by booting in to Recovery Mode.
o turn ON in Recovery Mode:
Step 1: Power off device completely (You Might need to Keep it on charge)
Step 2: Press and Hold "power" + "Vol up" for 5 sec
Step 3: Notice it flash boot screen twice
Step 4: Enter recovery menu use vol up and down to navigate
Step 5: Press power button for confirmation
Step 6: Wipe cache partition.
if clearing the cache partition doesn't help, you can also try resetting your device by formatting it to factory settings (ALL DATA WILL BE DELETED). for this Repeat the Steps upto 5, then use Step 6: Wipe data and clear cache.
Post Thanks if it helps
Mar 26, 2014 | Samsung Tablets & eReaders
Samsung Transfix wont turn on
if ur inside charger piece isnt out of place (u can find out by charging it on a duracell mygrid) then try a hard reset Press and hold the Volume Down + "R" in Qwerty Key + Power keys at the same time When the device displays "Samsung", release the power key only Continue to hold the Vol Down and back keys until you see the "Android system recovery" screen, then release all keys Press the vol down key until "wipe data/factory reset" is highlighted Press the home key Press the vol down key until "Yes - delete all user data" is highlighted Press the home key Once finished, and returns to the main recovery menu, press the home key again to reboot.
Jun 30, 2012 | Samsung Transfix
My mp3 player froze and i cannot reset.
You have to connect it to the computer and try to format it.
To reformat your Philips GoGear, you've to start WMP(WindowsMediaPlayer10series, than click on the button synchronize. At the top of this window is a button at the right corner which commands the formation.
BUT in case the computer is not detecting and nothing is helping then try this procedure as follows:---
Follow these steps exactly:
1 Reset your player first by inserting a pin or sharp
object into the reset hole at the back of the player.
2 Launch Philips Device Manager from Start > Programs >
Philips Device Manager. Select the Repair Tab.
3 While pressing the Vol + on your device, connect it
to the PC.
4 Confirm Yes when you see the screen , you can release
the Vol + now.
5 Choose your device name (SA5245/37) in the box.
6 After the repair completes , click OK and continue using
your player as usual.
If still the same problem then its a problem with internal inbuilt battery.For this the unit needs to be disassembled but its not easy.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Philips GoGear SA5245/37 Digital Media...
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
Go Gear Not Responding
Open up the device manager program.
Push the reset button on the device with a pin.
Press and hold the Vol + button whilst plugging into the PC.
Device Manager should go into repair mode.
Follow the on-screen prompts.
When finished, disconnect usb and reconnect quickly. Player should say loading, and then go into transfer mode.
Disconnect and reconnect player again. Screen should say
Updating.
Repair is now complete.
* If player flashes "Initializing" & "GoGear" alternately, then resatart the process again. If it still doesn't work then there's not much else you can do.
Feb 08, 2008 | Philips GOGEAR SA6045 MP3 Player
Wont Play unless hooked to charger
Player can be reset from a lock up by pressing and holding "PLAY/PAUSE" and "Vol +"
Try updating the firmware with Device Manager on the product CD.
Jan 09, 2008 | Philips HDD082 MP3 Player
Philips SA5125/37 MP3 Player Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
