Question about HP Color LaserJet 2600n Printer
Hp laserjet color printer gets stuck on initializing and the lights stop blinking. printer will not respond.
techguru005
  • 28 Answers
SOURCE: HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Posted on Feb 22, 2008
acdr
  • 1913 Answers
SOURCE: ''Page too complex'' message on HP color laserjet 2840 Multifunct.
go to printer and faxex then enable advanced features in your printer po\roperteis.
Posted on Nov 15, 2008
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 73 Answers
SOURCE: HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Posted on Apr 14, 2009
  • 19 Answers
SOURCE: HP 4600 Color Printer stays in "Initialize" Mode
If you are using a jetdirect network card it could be the cause of your problem. Pull the network card and restart the machine. Seen it a couple of times
Posted on Jul 28, 2009
My Hp 1300 laserjet printer doesnt get ready after initializing but giving orange blinking light, what could be the solution because i have checked the toner is in properly .
Remove the paper and re-loaded it, if it still giving you the blinking, turn it off and hold the go key down while turning it on then release it, this should rest any errors, worse case you have a bad fuser.
Jun 15, 2010 | HP LaserJet 1300 Printer
When i send a file to print from my mac (OSX 10.4.11) i get the error message in the printer box ''Printer not responding''I am using the HP 2500 Color LaserJet printer. It was working fine and just...
Connect the computer via fire wire to another working one.. and remove the two sleep files. Start your MBP holding down the T key The issue is a corrupt sleep file. once deleted your computer will work perfectly
Nov 11, 2009 | HP Color LaserJet 2500L Laser Printer, up...
Paper gets stuck
Remove toner from printer and check in side area one gray color roller will be there with blue lock remove roller
clean the gray pickup roller and check if its get smooth its need to be replaced
place 5-10 paper and check for prints if it’s picked properly
Nov 08, 2009 | HP LaserJet 1100 Printer
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Jul 25, 2009 | HP LaserJet 4600dn Color Printer
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Nov 14, 2008 | HP Color LaserJet 2600n Printer
Orange blinking light
hp colour laser jet 2550n while giving printing command it shows orange led blinking it dosen't print please help me.
Jul 24, 2008 | HP Color LaserJet 2550n printer + HP Color...
Printer problem
Turn the machine off and wait 5 minutes then turn back on it is possible that the machine engine firmware has locked up. Try this if not goto the hp website and you should be able to download firmware for that machine which updates via USB.
Give this a try and I hope it helps you
Thanks J
Jan 05, 2008 | HP Color LaserJet 2600n Printer
Hp laserjet 4550dn, how do you initialize thehard drive?
Try taking the disk out and format it on a PC first.
Aug 08, 2006 | HP Color LaserJet 4550dn Printer
HP Color LaserJet 2600n Printer Logo
487 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
