Question about Motorola Mobility Moto Q
When I jostle the phone it will dial a number from my contacts. Is there a way I can disable the dial pad?
  • 122 Answers
Pressing the Home Key then the Space Bar will temporarily lock the key pad, can be un locked be pressing the Left Soft Key
Posted on Sep 14, 2010
  • angela684 Dec 25, 2010
    q: WHAT'S THE LEFT SOFT KEY? I'VE HAD THE SAME PROBLEM...HOWEVER, I DON'T WANT TO LOCK THE KEY PAD AND CAN NOT UNLOCK IT
Help i have just transferred a sim from one S5 to another and want to transfer the number as well.vodafone tell me mobile settings,then profile then change number.were do i find this
if the phone does not ring when the number is dialed
The mobile number has to be done by Voda phone. The IMEI has to be put into the Voda Phone network against the Phone number.
Dial #06# into the phones dial and the IMEI will show .
Note the IMEI
if you want the phone to have the mobile number in the sim for labeling it.
Apps - Contacts
touch finger on the plus
touch finger on Sim Card
go down to phone number
put in phone number
press on done from key pad
press on save top right of screen
Jan 09, 2017 | Cell Phones
Number "6" doesn't work making it impossible to dial out for any phone number with a "6". Any suggestions other than replacing the entire system?
Just a guess, but I would say that the number 6 pad is not making good contact with the circuit board. After time, the contacts on the back of the number will become dirty from the oil on your fingers. If you can take the phone apart, you can clean the contacts on the circuit board with an eraser and the back of the number pad with rubbing alcohol.
May 12, 2016 | Lands Phones
Operating manual-how to find a contact name by alphabet,eg.BOY
goto Dial pad/people/contacts then press search and enter name you'll find matched contact name and numbers after typing.
Jan 21, 2013 | HTC F5151 Freestyle AT&T 3G Mobile Phone -...
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
Hi, when i pickup the phone to make a call, after i press 1 number 4 numbers are dialed? how can i fix this?
there could be moisture/ sweat logged inside the keypad. open the phone carefully , be careful not to damage the phone connections, open the pad side and use a air heater to warm up , this will clear the pad contacts.
Jun 30, 2010 | Cell Phones
My screen freezes when I dial
Decided to try running a magnet over the phone front & back horizontally and vertically, like I had read other people did to fix other freezing problems. IT WORKED!!! :D
Aug 14, 2009 | LG Xenon GR500 Cell Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Cannot activate dial pad
Do a hard Reboot, Turn your phone off and wait 10 secs then turn it back on it should be fine.
May 03, 2008 | LG Prada KE850 Cellular Phone
Dialing on 755p
Ok theres two ways to do this, heres 1 way: press menu while you our on the phone display (the button to the right of alt) use the 5 way navigator to move to the right, scroll down to phone display options. Below the Show Dial Pad/ Show Wallpaper, you'll see where it says typing dials phone number change that to typing starts contact search. This will permanently make it liek your old treo. If you wanna dial numbers press the white button to thte left of z and start dialing the numbers.
Version 2: If you dial normally it will dial numbers, if you press th white button to the left of z then type contact name also works.
hopes this help
Masalama
Feb 08, 2008 | Palm Treo 755p Smartphone
Speed Dialling
You should be able to either go to the phone book and there will be an option for "speed dials" or it may be able to go the the contacts itself and "edit" them and change the speed dial.
Jul 05, 2007 | Sony Ericsson K750i Cellular Phone
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
102 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
