Question about Whirlpool Washing Machines
How do you remove the agatator on model lsq9549lwo
    Genius:
  • 1,073 Answers
Remove the top of the agaitator, some have a cap some a detergent cup
remove the clear inter cap and o ring
the bolt holding the agaitator can be accessed then with a nut driver
remove the nut and lift the complet agaitator out of the machine
Posted on May 17, 2008
Agator doesn't work
Is this a whirlpool washer? The agitator dogs need to be replaced. Remove top cap on agitator, then plastic cover inside it, then remove bolt, then pull agitator off. Top can separate from bottom by standing on bottom and pulling up on upper. Go to Repairclinic.com to find agitator dogs.
Nov 19, 2011 | Whirlpool Washing Machines
How do i remove the agatator on a awm593w washer it is leaking grease
I used a tie down strap, I put one hook under the lip of the agatator on one side then the other hook 180 degrees opposite the first, grabbed both straps and lifted it right off the drive bell. Really easy. Good luck Don
Feb 01, 2010 | Speed Queen AWS44NW Top Load Washer
What cu. ft. size is my Whirlpool top loading washer model # LSQ9549LWO?
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
Top half of agatator don't turn
Remove the agitator. Place it on the floor. Put your feet on the base and yank the top portion off. Replace these:
124bfd8.jpgPart number 80040 agit dogs(4)
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
When spining it makes a gravel noise like there is dirt under the agatator and when the cycle has finished all bits of hard dirt have come out into the wash.How do l remove the agatator to clean under it?...
What type washer do you have? make? model?
Some agitator pull off, some are screwed down, some are bolted down, the bolts would be under the cap or fabric dispenser.
Jul 09, 2008 | Washing Machines
MAYTAG TOP LOAD WASHER MODEL PAVT244AWW, STRING FROM A CURTAIN IS CAUGHT IN THE AGITATOR. HOW DO I REMOVE AGGITATOR TO GET STRING OUT?
remove the fabric despenser from the top of the agatator, under the despenser is a 1/2 inch bolt, a ratche with a 6 inch extention works well, remove the bolt and the agatator will lift up off the transmission shaft
Apr 12, 2008 | Washing Machines
Washing Machines Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal De
