Question about Shure SE110 Consumer Headphones
I own a Shure SE110 headphones, I believe the headphone wires have become loose or disengaged where the headphone cords join into the plug. Is it possible to fix this.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
I'd suggest sending them to Shure. For a nominal fee, they will send you a new pair.
Posted on Sep 20, 2010
Headphones drop out
Cord is probably broken internally. If you are not good with wires and soldering and it is out of warranty, find someone who is or buy new headphones. You can manipulate the wire until it works and tape it in that position for a temp fix, otherwise the cord is shot.
Aug 25, 2012 | TDK 61821 NOISE-CANCELING HEADPHONES NC150
I have bought a pair of Shure SE210 headphones for my iphone but the sound is lacking all the low frequencies for most of the music or videos i try to play. The headphones work perfectly on any other...
No, there are no known issues. Typically a lack of bass response is due to a poor seal with the ear canal. The headphones use sealed ear canal is a resonant bass chamber. Thus, if there is not a good seal, the bass will be significantly lower.
Jul 07, 2010 | Shure SE210 Consumer Headphones
Right headphone goes in and out
Unfortunately, you'll probably have to send the earphones to Shure for repair/replacement.
Oct 31, 2009 | Shure SE110 Consumer Headphones
RH bud on shure SE110 does not work
There's a bad solder joint or broken wire somewhere.
Oct 22, 2009 | Shure SE110 Consumer Headphones
Cracked wires
I recommend getting some Shure headphones if you are into the in-ear style. In reality, better sound is achieved by larger older style headphones like a pair of Ultrasones or Sennheisers.
http://www.sweetwater.com/c412--Shure--Headphones
older style
http://www.sweetwater.com/store/detail/HD280Pro/
Jun 19, 2009 | Bose in-ear headphones - Black with...
Can it be fixed or replaced?
Assuming the cord just does like any standard audio cable and transmits sound one way from the 3.5mm jack to the headphones then you could get some wire and solder it in at either end, then just use some stage tape to wrap around the join.
Were they normal headphones I'd just suggest some new ones, but noise cancelling are expensive IIRC.
Jul 13, 2008 | Sony Audio Players & Recorders
Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Jun 05, 2008 | Bose in-ear headphones - Black with...
Shure in-ear phone
I plugged the earphones in another mp3 player and they worked fine. So the interruption of sound must be in the connection between the Mp3 and earphone plug. So the earphone wiring gets a verdict of not guilty. I will do some experiments involving the female plug on the original mp3 player. That is where the problem is.
Feb 12, 2008 | Shure (E2G) Consumer Headphones
Can't hear sound on one of the headphone's speaker
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
Good Luck,
- Jim
Jan 24, 2008 | Radio Communications
Shure SE110 Consumer Headphones Logo
214 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
