Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
My Dryer resets itself to the wrinkle release mode for 18 minutes regardless of what we set it for. During the 18 minute cycle, it beeps 4 - 6 times in quick succession. After the cycle ends, it will still occassionally beep a few times. Sometimes it will beep during the cycle, shut off and not allow us to restart it. We keep it unplugged most of the time now. There is nothing in the lint trap. We had a similar problem four years ago, but the dryer was still under waranty. They replaced the mother board, and it worked fine. I've called a service provider about replacing the mother board again and was quoted $391 for the job. Do you think that is the problem? Is there a less expensive way to fix it?
  • 8 more comments
  • barbuff08 May 22, 2008
    I'm willing to give it a shot - where can I order the part and get directions to install it?
  • hairraiser Jun 28, 2008
    Sae thing just started happening to my dryer. Just keeps beeping.
  • dobin Jul 31, 2008
    My neptune dryer has the exact same symptoms as barbuff08's. I replaced the motherboard or(control board) and it did not cure the problem. Panel lights up normally most of the time, but pushing on any of the buttons sometimes does nothing at all.
    Regards---Harold Walker
  • akusmin Aug 08, 2008
    the dryer just started beeping every 10/15 sec. unplugged it for several hours and that lasted about 1/2 hour and started again. Guess the next thing is to go into the electric end
  • speikerdlth Aug 13, 2008
    My Dryer resets itself to the wrinkle release mode for 18 minutes regardless of what we set it for. During the 18 minute cycle, it beeps 4 - 6 times in quick succession. After the cycle ends, it will still occassionally beep a few times. Sometimes it will beep during the cycle, shut off and not allow us to restart it. We keep it unplugged most of the time now. There is nothing in the lint trap.The dryer exhaust is clear, no restrictions. Is is overheating and tripping a safety?Or is the mother board bad........again.
  • alvernaz3 Aug 16, 2008
    OK, my Maytag Neptune dryer (MDE5500AYQ) starting acting up a few weeks ago.
    It would only work on Wrinkle Release mode for 18 minutes regardless of what we set it for.
    After a few days during the 18 minute cycle, it would beep 4 - 6 times in quick succession and shut down.
    Soon, the entire control panel was dead and nothing worked at all, although I was able to start (and only start) the “service” mode by pressing the “damp dry & time-“ buttons.
    Researching online led me to believe the control panel was at fault. Calling around I was quoted $350+ to get it replaced by a tech. So I ordered a new one.
    The existing CP was model #33002918, the control board I purchased is a model #33003028; which I was told is a direct replacement.
    After installing the replacement, not much better:
    Control board is lit up, still on Wrinkle Release mode for 18m cycle, the start/pause button is flashing, but nothing works. I can not active the service mode, but was able to run a membrane pad check…all lights work….whoopee!
    Help!!
  • nitross Dec 09, 2008
    If anybody found a solution to this issue, please post! There seems to be several people with the same problem. If it's not the control panel, I don't want to spend the $200.00 if I don't have to. Please e-mail me directly if you can - bgordon (AT) lakeariel.net. Thanks!
  • Anonymous Jan 02, 2009
    We have the same problem. The dryer kept resetting itself to 18 minute wrinkle release. We found we could not use the sensor dryer part so we started using the timed drying. Today it reset to wrinkle release again and I couldn't get it off that setting. It was periodically making a faint beeping sound. We unplugged the dryer and plugged it back in with no success. I just went back out to try again and it started and stopped. I tried again and it started and so far so good. From the look of these posts, I shouldn't hold my breath. Has anyone found an actual solution yet short of suing Maytag? I also noticed that our washer was the topic of a class action suit or which we were not notified. The washer grows mold and we are forced to run bleach through it regularly to try to get our clothes clean without the smell of mold. The time to redeem the coupons for a new dryer was up three years ago!!! (Tells you how long we have been suffering with this.) These appliances were our first and last Maytags.
  • Toms Jun 23, 2013
    I have the same problem and now it is both the washer and dryer control lights up and starts beeping in the middle of the night . You can't shut them off or reset them sometimes you can't even use them .so you have to unplug them from the power outlet . I wonder what has caused this to happen in the first place, maybe this is do to the many power outages we have had here and one low voltage or less than 120 volts to the circuits in the house. I still want answers to this phenomenon
  • Anonymous Mar 17, 2014
    it doesn't do it all the time mostly after a couple loads
Our maytag neptune dryer control board keeps beeping and flipping into all its options the top and bottom dryer do i reset the computer? we've unplugged it but it continues
Posted on Jul 06, 2012
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
Posted on Aug 19, 2008
  • 45 Answers
It does sound likea control board issue, the control boad is only about 150 and very easy to install about 8 screws. is very odd that you keep having problems you may have an electical issues these are good units most of the time
Posted on May 22, 2008
Periodically, the display will change to the wrinkle release mode from sensor dry mode (all by itself), and the timer will show 18 minutes remaining. If I switch it back to sensor dry mode, the display...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if that is fine the problem is either the door switch or the control board. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Maytag Neptune MCE8000AY Electric Dryer
We installed a new control board on a maytag neptune dryer MDE5500ayw. everything is installed correctly but the dryer will not start. The lights are on and there is no fault showing. How do we reset the...
are you positive it was the board and not something else wrong?check to see if you have power to the motor with a meter,if you do you have a bad motor,also check the thermal fuse.you need to get in there with a meter and check things out
Aug 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer keeps resetting
This may be a problem that only a repairman can fix. There may be an electronic board that has to be replaced.
Jun 08, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune gas dryer beeps.
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Apr 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Switches to wrinkle release and changes to 18 on display.
Check the vent coming out the back. It may be plugged up not alowwing proper airflow. You might just unhook it for one load to see if that is the problem.
Apr 08, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Problem when drying gets to 1 minute mark
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
May 29, 2007 | Maytag Neptune MDE6700A Electric Dryer
Timer problems
Yes it probably is but check the keypad also.It could have a short in it.
May 26, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
3,453 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
