Question about DXG Technology DXG-506V DV Digital Camcorder
I'm trying to set up a new DXG-5B6V. I get an error message "no device detected. Connect a device" The camcoder is connected to a functioning USB port?
All I get when I try to download the drivers is Internet Explorer cannot display the webpage
Posted on Jan 12, 2011
Need the manual for dxg-5b6vb 720p ocean blue
You may download the manual here.
The 5B6V uses SD and SDHC cards.
Dec 25, 2011 | DXG Technology DXG-506V DV Digital...
Dear ,i can notconnect my miniDV tape cam to Laptop ,,,,,,,,,,,please giude me. ihave firewire cable and USB cable also.
Make sure you already been installed its software to your laptop ( for fast and best connection).
While your camcoder turning off, connect the usb cable ( small jack in your camcoder) and standard jack for your laptop. Now turn on your camcoder. If you have pre- installed software in your laptop, it will detect automatically your camcoder. If doesn't work try to search manually your camcoder trough 'my computer' or check connection on right lower side of your screen.
god luck
Aug 18, 2010 | Video Cameras
Uploading pics
- Connect the smaller end of the USB
cable into the USB port of your DXG.
- Connect the other end of the USB cable to your computer's USB port.
- The Digital video camera’s LCD Panel will turn on and will display
the PC Connection Menu
- Press the select button up or down button to select Mass Storage
Device option on the menu screen.
Goto my computer, you can see new 1 drive appear (or 2 if you have SD card in your DXG). So now you can copy/upload your pictures to your computer hard disk.
May 31, 2009 | DXG Technology DXG-305V Digital Camera
Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Feb 25, 2009 | Canon PowerShot SD1000 Digital Camera
Unale to transfer data thru USB cable
was using my DCR TRV 285E model Sony camcoder without any trouble. After a long when i tried to connect the same to my laptop i got message you required ieee1739 port. what can i do for this?
Sep 13, 2008 | Sony DCR-TRV285E Digital-8 Digital...
The power will not turn on-DXG -305V
used a usb cord come with DXG-305, you dont need batteries to connect it to computer, because usb deliver the power to the cam
Nov 19, 2007 | DXG Technology DXG-305V Digital Camera
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Unable to connect calculator to computer.
Try opening the software on your PC. Set the connection to USB and connect your calc. On the calc press the right shift key followed by the right arrow key.....software should now recognize the calc.
Mar 19, 2007 | HP 49g+ Calculator
DXG Technology DXG-506V DV Digital Camcorder Logo
137 people viewed this question
Top DXG Technology Video Cameras Experts
SHARCNET-USA
SHARCNET-USA
Tony Parsons
Tony Parsons
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
