I bought a 30" belt drive fan for my greenhouse at a 2nd hand store. The motor has red, black and white leads. I want to hook it up to a "cooling stat" and also put a variable speed control on it. Or does the red/black indicate a 2 speed fan? Thanks. Richard Meneghelli.
  • 455 Answers
Hello RED is low speed BLACK is high speed.Decide which one you want to be your fast speed.Tape off the unused one.Hook up your speed control as normal.
Posted on Sep 15, 2010
Testimonial: "Thank you -- I thought that the case. Thanks for the quick response. Richard M"
Why don't fan blades rotate?
Sadly Hunter doesn't want people dismantling their stuff and replacing broken or burnt out pieces. They'd rather you buy a new one. If the motor has burned out which is possible a solution depending on how handy you are is simply hunt down a similar replacement and reconnect it.
Make sure the new motor has the exact same leads and connectors as the old one had as some Hunter fans have more than two leads. The model I have has four leads: a black, a white, a green and a red as my model has integrated lighting controls by passed by the motor.
I bought a simple blower motor with the same rating only two wires and with a bit of solder and wire I hooked up the motor and lights separately. The new motor is much faster than the older one so I had to add a tiny 1-way 500 watt dimmer switch to manually turn down the speed.
Aug 30, 2015 | Hunter Dryers
Tip
Fuse list ford contour
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit
Engine bay fuse box
1 80 Black Power supply to main fuse box
2 60 Yellow Radiator fan
3 60 Yellow ABS
4 20 Yellow Daytime running lights
5 30 Light green Fog lamp
6 30 Light green Not used
7 30 Light green ABS
8 30 Light green Air pump
9 20 Light bue PCM module
10 20 Light bue Ignition switch
11 3 Violet PCM memory
12 15 Light bue Horn & hazard flasher
13 15 Light bue Oxygen sensor
14 15 Light bue Fuel pump
15 10 Red Right-hand low beam
Passenger compartment fuse box
16 10 Red Left-hand low beam
17 10 Red Right-hand high beam
18 10 Red Left-hand high beam
19 7.5 Brown Heated door mirrors
20 10 Black Windshield wipers
21 30 Light green Electric windows
22 7.5 Brown ABS
23 15 Light bue Reverse lights
24 15 Light bue Brake lights
25 20 Yellow Door locks
26 20 Yellow Main light
27 15 Light bue Cigarette lighter
28 30 Light green Power seats
29 30 Light green Heated rear window
30 7.5 Brown Engine management
31 7.5 Brown Instrument pannel lights
32 7.5 Brown Radio
33 7.5 Brown Front and rear sidelights (left)
34 7.5 Brown Interior lighting & clock
35 7.5 Brown Front and rear sidelights (right)
36 30 Light green Air bag
37 30 Light green Heated blower
38 Unused
Relays Color Circuit Location
Engine bay fuse box
R1 Green Daytime running lights (Canada)
R2 Black Radiator fan (high speed)
R3 Blue AC cut-out
R4 Brown AC clutch
R5 Dark green Radiator fan (low speed)
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R9 White Low beam headlights
R10 White High beam headlights
R11 Brown PCM power supply
R12 White Interior and courtesy lights
R13 Yellow Heated rear window
R14 Yellow Heated blower
R15 Green Windshield wiper motor
R16 Black Ignition
R17 Unused
R18 Black One touch window switch Driver's door
R19 Blue Cruise control cut-off Central fuse box bracket
R20 Unused
R21 Unused
R22 White Fog lights Interface module bracket
R23 Black Turn signals Steering column
R24 White Left-hand flasher Door lock module bracket
R25 White Right-hand flasher Door lock module bracket
R26 Unused
Bulbs / Lights Wattage Type
Low beam headlamp 55 9006 Halogen
High beam headlamp 55 9005 Halogen
Parking / Side light 5 2357A Wedge
Front turn signal 21 2357A Bayonet
Rear turn signal 21 1157 Bayonet
Tail light 21 1157 Bayonet
Stop light 21 1157 Bayonet
High mount stop light 5 2723 Bayonet
Fog/Driving light 55 893 Halogen
License plate 5 6418 Festoon
Reverse light 21 1156 Bayonet
Front sidemarker 5 2357A Wedge
Glove box
Map light 5 64111 Wedge
Dome light 10 6411 Feston
Step/Courtesy light
Trunk/Cargo area
Engine compartment 10 89 Wedge
Instrument-general
Automatic trans indicator
on Apr 15, 2015 | Ford Contour Cars & Trucks
I have a 1999 Ford contour lx neither the brake lights nor the turn signals will work what would cause this
a fuse number 24,,,
Fuses Rating Color Circuit Engine bay fuse box 1 80 Black Power supply to main fuse box 2 60 Yellow Radiator fan 3 60 Yellow ABS 4 20 Yellow Daytime running lights 5 30 Light green Fog lamp 6 30 Light green Not used 7 30 Light green ABS 8 30 Light green Air pump 9 20 Light bue PCM module 10 20 Light bue Ignition switch 11 3 Violet PCM memory 12 15 Light bue Horn & hazard flasher 13 15 Light bue Oxygen sensor 14 15 Light bue Fuel pump 15 10 Red Right-hand low beam Passenger compartment fuse box 16 10 Red Left-hand low beam 17 10 Red Right-hand high beam 18 10 Red Left-hand high beam 19 7.5 Brown Heated door mirrors 20 10 Black Windshield wipers 21 30 Light green Electric windows 22 7.5 Brown ABS 23 15 Light bue Reverse lights 24 15 Light bue Brake lights 25 20 Yellow Door locks 26 20 Yellow Main light 27 15 Light bue Cigarette lighter 28 30 Light green Power seats 29 30 Light green Heated rear window 30 7.5 Brown Engine management 31 7.5 Brown Instrument pannel lights 32 7.5 Brown Radio 33 7.5 Brown Front and rear sidelights (left) 34 7.5 Brown Interior lighting & clock 35 7.5 Brown Front and rear sidelights (right) 36 30 Light green Air bag 37 30 Light green Heated blower 38 Unused Relays Color Circuit Location Engine bay fuse box R1 Green Daytime running lights (Canada) R2 Black Radiator fan (high speed) R3 Blue AC cut-out R4 Brown AC clutch R5 Dark green Radiator fan (low speed) R6 Yellow Starter R7 Brown Horns R8 Brown Fuel pump R9 White Low beam headlights R10 White High beam headlights R11 Brown PCM power supply Passenger compartment fuse box R12 White Interior and courtesy lights R13 Yellow Heated rear window R14 Yellow Heated blower R15 Green Windshield wiper motor R16 Black Ignition R17 Unused R18 Black One touch window switch Driver's door R19 Blue Cruise control cut-off Central fuse box bracket R20 Unused R21 Unused R22 White Fog lights Interface module bracket R23 Black Turn signals Steering column R24 White Left-hand flasher Door lock module bracket R25 White Right-hand flasher Door lock module bracket R26 Unused Bulbs / Lights Wattage Type Low beam headlamp 55 9006 Halogen High beam headlamp 55 9005 Halogen Parking / Side light 5 2357A Wedge Front turn signal 21 2357A Bayonet Rear turn signal 21 1157 Bayonet Tail light 21 1157 Bayonet Stop light 21 1157 Bayonet High mount stop light 5 2723 Bayonet Fog/Driving light 55 893 Halogen License plate 5 6418 Festoon Reverse light 21 1156 Bayonet Front sidemarker 5 2357A Wedge Glove box Map light 5 64111 Wedge Dome light 10 6411 Feston Step/Courtesy light Trunk/Cargo area Engine compartment 10 89 Wedge Instrument-general Automatic trans indicator
Apr 15, 2015 | 1999 Ford Contour
Light and fan work but does not work with wall switch
This would mean that that constant power to the fan and light is not wired through the switch right, or not wired into the switch at all. Most ceiling fans that have a light kit will have a Black, White, Green, and Red wire that comes from the ceiling and hooks into the fan and light. If it was done correctly, then the Green wire would be ground, the White is your neutral which is hooked to the other White wire, the Black wire is usually power to the light kit which will also hook to another black wire, and the Red is to the fan. Sometimes the Red and Black are reversed. If any of these wires are wired wrong, that could possibly lead to a constant power to the fan and light kit.
Feb 02, 2010 | Hunter Dryers
WIRING DIAGRAM
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
I have a three wire lead out of my junction box (bare wire ground/white/black)and my new GE JTP 30 electric oven has a four wire (extra red). What is the wire configuration needed for reinstalling?
hook from the range the green and white wire to the bare copper wire from the house
hook the black wire from the range to the black wire from the house
hook the red wire from the range to the white wire from the house
Apr 24, 2008 | Kitchen Ranges
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
