Question about Pentair 1.0 Hp Whisperflo Pump
Pentair poolpump i hp trips breaker when turned on at timer
  • 366 Answers
Depending on the age of the pump, it's possible for the windings in the motor to have developed a direct short. This can be gradual, may or may not cause the capacitor to fail, or it can happen abruptly. If the wiring is tight and not shorted out, most likely the motor windings are bad. (this is assuming the supply power is sufficient and has worked fine in the past.)
Posted on Sep 16, 2010
Why does pump trip breaker everytime it is turned on?
try turning the shaft from the back with it off it might be rusty then try if it still does that you need a new pump motor or pump
Sep 03, 2014 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Electronics breaker keeps tripping switched
write down all auxs then unplug all then turn on and plug one at a time till it pops probably heater ignitor if ok bad pump motor
Aug 18, 2013 | Pentair Intellitouch Power Center Includes...
Pentair intellitouch electronic breaker keeps tripping
check pump see if popping or heater unplug auxs until it doesn't pop if keeps maybe bad transformer
May 04, 2012 | Pentair Intellitouch Power Center Includes...
My brand new 1.5 hp, 230/115 v pentair runs for several minutes, gets hot and then shuts off. (not tripping the breaker) ...wiring was already in place on previous 1.5 hp, 230/115 jacuzzi brand pump for...
It is probably only getting 115V from your circuit which will cause it to overheat and trip the overload yet it will not draw high current which would trip the breaker. Can you confirm your line voltage with a meter? If it is suppoed to be a 230V line then look for a bad leg of power, again, checking each leg to ground using a meter.
John
May 28, 2011 | Pentair 15 Hp Superflo Swimming Pool Pump
Pump switching off for about 10 -20 seconds, then back on. Hapens about every hour
the little house on top of the motor has a capacitor in it 90% of the time thats whats wrong with this motor it's eather a 30 or a 35 mf .
pull this off the motor and search your area for pool pump motor repair, free testing ,use your zip code in the search, ask if they can test a capasitor for you.. wait to take capacitor off till the motor cools off
about a $20.00 fix
hey if'n i was of help vote..thanks ..jay
Aug 08, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
No power to heater minimax 400 pentair
turn all breaker off that are related to the pool equipment even the one at the main panel. if not check for power 220 v at the timer if power check the wires if not power the breaker may need to be replace
Sep 07, 2009 | Pentair 400k Minimax Ch Ng Mv Heater
1 1/2 HP Pentair Pinnacle Pump keeps tripping the breaker. What would the problem be and how can I fix it?
The motor and/or electrical system is damaged and need to be repaired. With the breaker off, disconnect the motor and insulate the wire ends. Turn the breaker back on and it should remain closed without tripping. If so, it is ok and you can turn it off and leave it so until the motor is fixed or replaced.
Find a local electric motor repair shop and have them inspect the motor. It will likely have to be replaced but taking it to them insures it is not repairable and also makes sure the new one will fit correctly. A new motor and seal would likely run ~$150 or so.
Sep 03, 2009 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
I am trying to install a SuperFlo 1 1/2 HP 115V pump The GFI breaker trips as soon as I try to turn it on.
pumps should not be connected to GFCI circuits they do pull a lot of juice at start time and this causes your GFCI to trip
Jun 15, 2009 | Pentair Superflo 1 1/2 Hp In Ground Pool...
Turned the timer switch on, the pump starts and one second later
reset breaker overide timer by tuning on if this works it is a timer issue
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pentair 1.0 Hp Whisperflo Pump Logo
253 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
