Question about Samsung HL-P6163W 61" TV
The fan connected to the lamp is making noise
    Sergeant:
  • 171 Answers
It could be that it has some dust stuck inside the fan or it could be that it is no longer working ok I found a place that has them
http://www.discount-merchant.com/SearchResults.asp?searching=Y&sort=13&search=HL-P6163W&show=25&page=3
Posted on Sep 14, 2010
When I turn it on fan runs and clicking noise but lamp light flashes yellownis this the bulb like to make sure before I spend that much money for one
Check with the Sony service center that serves your area. Generally when the lamp indicator flashes, it's either due to a bad lamp or the connections to it...
Nov 03, 2013 | Sony VPL PX30 Multimedia Projector
Projector makes lots of noise
Yes, that can solve the problem because there's also a possibility that the lamp is the one that is causing the noise..
Hope that helps........
Aug 18, 2008 | InFocus ScreenPlay 5700 Multimedia...
My toshiba mod. 52hm95 lamp cooling fan is making noise and i am having trouble locating a replacement
Fan like noise may be a fan or the color wheel---color wheel spins at high speed(lamp faces it) and when failing you will have a high pitched or fan like sound---hard failure and you will hear a grinding sound.
May 16, 2012 | Televison & Video
Replaced lamp in my HD 61Z575, but when I turn on my TV, nothing happens (no fan noise). After ~10 seconds, the Light LED starts blinking rapidly. Could it possibly be the brand new lamp? Ballast?
The old lamp was in there before the fan work?U replaced the lamp u put the door back on did u make sure the safety latch is off and tightly closed with the the lamp door.The continue blinking LED light does it make alot of clicking noises too.Yes,then the Ballast board it is dead too.The Ballast board only job are to help the projection lamp to ignite to work.
Aug 27, 2011 | JVC HD-61Z575 61" Rear Projection...
I have a noise comming from the lamp area the fans are working fine i think it is the lamp do they make a noise when they are anout to break
hi,
if the sound is not coming from the fan then check the connections of ur lamp, if there is any loose contact in the connection there will occur a sound. also fan will produce some noise if its bearing have some problem. it will work fine but produce noise. the lamp will make noise at the starting time afterwords it will not.
ok
Dec 31, 2010 | Samsung HLN5065W 50" Rear Projection...
RCA 61" TV (HD61LPW165) Lamp Fan making noise
Here ya go:
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=662661
Much better longer life part. 80x80x25 mm 35 cfm with rotor lock wire. Connect the yellow to the blue wire on the tv, black to black red to red.
Sep 25, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
May 23, 2009 | InFocus X1 Multimedia Projector
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
LAMP INDICATOR LIGHT FLASHES 1X EVERY 5 SECONDS
You need the LSYC0022 kit to. To prevent lamp bad again
Jun 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Samsung dlp tv hls 5688w problem
Possibly a bad fan. operate the set for at least an hour to warm it up then shut it off does the noise continue for a moment? If so its probaly the fan for the lamp that is making the noise.
Mar 20, 2008 | Televison & Video
Samsung HL-P6163W 61" TV Logo
257 people viewed this question
Jerry Greenberg
Jerry Greenberg
