Question about Epson Artisan 700 InkJet Printer
My epson Artisan 700 have error ( paper is jammed in the product)
    Sergeant:
  • 308 Answers
If you mean it comes up with a paper is jammed in the product error message when turned on, AND you have confirmed that there is no paper anywhere to be found inside the product, then you most likely have a defective sensor or electronic problem inside the unit that is not economically feasible to repair. Epson's web site is not at all helpful for this problem.
Posted on Aug 15, 2011
  • 3 Answers
I had the same problem and noticed that when I turned the printer on the print head would start to move and then the paper jam message would come up. I solved the error by gently pulling on the reddish/orange and clear bands and it worked fine after that. The bands are located towards the front and can be accessed by opening the top cover. I have included a picture of where the bands are. My epson Artisan 700 have - a741bb15-6f3f-48b2-8aa1-a65c38924e27.jpg
Posted on Sep 03, 2014
What printers will take espon ink cartridges 99
The products that uses the T099 ink cartridges are the following:
  • Artisan 700
  • Artisan 710
  • Artisan 725
  • Artisan 730
  • Artisan 800
  • Artisan 810
  • Artisan 835
  • Artisan 837
Sep 07, 2014 | Epson Office Equipment & Supplies
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 835. Just set up. Printed fine. Tried to eject DVD/CD tray. Did not eject. I turned off unit. Turned back on. Now constantly says I have a paper jam when there is none. Cannot use.
Hi. I Have an Epson printer too and become to send the paper jam error when there not a paper jam on the printer. Check the ink cartrige bay with the printer off. The ink cartrige bay have to stay all the way to the right. If not push carefully to the right. Start again the printer and see what happens. This cause in certain ocassions the paper jam error. I hope this tip can help.
Aug 13, 2013 | Office Equipment & Supplies
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
My artisan 700 keeps pilling in multiple sheets and then jams.
hi there, il be glad to assist you.
If multiple pages feed at once, remove the paper from the tray, fan the edges to separate the sheets, then reload it. if Paper Jams Inside the Artisan 700 Series: Open the scanner. Remove the paper as shown, including any torn pieces. Squeeze the hooks and remove the cover inside the Artisan 700 Series. Remove the paper as shown, including any torn pieces Reattach the cover. Close the scanner. if after doing all of these still same issue persists, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 16, 2010 | Epson Artisan 700 InkJet Printer
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
Paper jam
try to fix with proper in place the roller .
Jan 11, 2009 | Office Equipment & Supplies
Epson Artisan 700 InkJet Printer Logo
548 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
