Question about Dymo LetraTag QX50 Thermal Label Printer
My dymo keeps saying error 1 what does that mean?
  • 19 Answers
SOURCE: dymo lextra tag xr
I was able to find the following error codes, however I realize they are for the Lextra tag QX50. I was unable to find codes for the Xr, so I e-mailed Dymo and will post a comment on this as soon as they get back to me.
For now, here are the QX50 codes, just in case they help:
LetraTag QX50 Error Codes trnsp.gif Question An error is dispalyed on screen when I attempt to print a label with my LetraTag QX50. How can I resolve this?
trnsp.gif Answer Error
Solution
Error 1
(Tape jammed or low battery)
  • Replace the cassette
  • Replace batteries
Error 2
(Big Font cannot be selected with characters in memory)
  • Select another font size
  • Select Big Font before entering text
Error 3
(Big Font cannot be selected with: box, underline, 2 line, or lower case)
  • Select another style format
Error 4
(Memory buffer is full)
  • Delete some of the entered text
Error 5
(Text is bigger than defined length)
  • Specify a longer tape length
Error 6
(2 line cannot be selected with the format)
Posted on May 19, 2008
SOURCE: error 1
I tried all three suggestions. Finally in despiration I took the plastic cap from a pen and forced the roller (feeds paper) to move, put the paper back in and closed the cover. When I tried to print it worked just fine.
Posted on Aug 25, 2007
SOURCE: error 1 dymo letra tag xr
Hola,cambiale las pilas,o mira haber si se ha atrancado.Esas son las 2 soluciones para el error 1.
Un saludo.
Posted on Oct 13, 2008
SOURCE: Error 1 message
Check the batteries and that there is nothing clogging up the tape area. Any little bit of tape can cause the error message to come up. Also if you put in say 4 new batteries and kept 2 older ones that show a little life still left, can cause the error message. Change all the batteries at the same time.
Posted on May 08, 2009
damien729
  • 221 Answers
SOURCE: I need a manual for the dymo letra tag. I keep getting error 1
Hello, Please find the link to your letra tag manual: https://global.dymo.com:443/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=68
Posted on Jun 11, 2009
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
What means ERROR 1?
Tape jam or battery low (see user guide, page 11). Please clean the cassette compartment and/or exchange the batteries.
Dec 07, 2011 | Dymo LetraTag QX50 Thermal Label Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
How do I reset my Dymo lablel maker I have ! ! ! ! ! ! when in use
!!!!!! is a (rather unhelpful) error code that means basically that it can't print for some unknown reason. If the tape is not jammed in the printhead, and the tape seems to move freely, then generally it means the machine is broken.
To be sure you can call Dymo tech support on 020 7341 55 29 (UK)
If it's under warranty, you can return by going here:
http://global.dymo.com/enGB/ServiceAfterSales/default.html (UK)
If not you'll need another one...
http://www.dymo-label-printers.co.uk/Dymo-Label-Maker.html (UK)
You don't say which model you have, but if it's the one in the picture it should still be under warranty as they're fairly new and come with a 3 year warranty (in the UK at least).
For US or other countries go to www.dymo.com and select your country, and then the returns and contact information can be found there.
Nov 04, 2009 | Esselte Dymo LabelManager 120P Compact...
Jun 11, 2009 | Dymo LetraTAG Thermal Label Printer
Error 1 message
May 07, 2009 | Dymo LetraTAG Thermal Label Printer
Dymo lextra tag xr
Solution
Error 1
  • Replace batteries
Error 2
Error 3
Error 4
Error 5
Error 6
May 04, 2008 | Dymo LetraTAG Thermal Label Printer
Letra Tag QX50 Error 1 message
Don`t close the back plane compleet, push print and pull on the tape, now it runs on mine. Close the back plane and everything is ok now, Good Luck!
Michel
Sep 20, 2006 | Dymo LetraTag QX50 Thermal Label Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
374 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
