Refrigerators Logo
Posted on May 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every thing in the frezzer/fridge is warm
My freezer fan is humming and i am noticing that my ice maker is not producing ice. then my fridge is not keeping things cold
Anonymous
Level 3:
Genius:
  • Master 1,073 Answers
  • Posted on May 17, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1073
Questions
0
Helped
392191
Points
2842
What is the model number of the fridge
Where is the ice maker fan for LG French Door Refrigerator?
The ice maker fan is located in the freezer and is part of the Grille Assembly ( LG part Name) Which is the removable back panel in the freezer. If you have an error code on the display such as ER/IF the fan is not rotating due to failure or ice accumulation in the fan blade. If you have no error code and the ice maker is not producing ice 2 things to check are...1. On the bottom of the ice maker there is a Test Button. Press and hold the button and the ice maker should rotate, Dump ice cubes and refill with water. If the ice maker does not cycle replace the ice maker. 2. Check freezer temperature. Freezer Temperature must be below 15 degrees to make ice. Ideally freezer temp should be 0 Degrees. If you have warm temps in the freezer there may be a sealed system issue preventing proper cooling.
Hope this helps.
Mike
My fridge is not cooling at all but the light is still on and frezzer is still working. Help
The cold air that you receive to your refrigerator comes from your freezer, so when you normally have a problem with a refrigerator not cooling you would check the freezer first. The first thing I normally check is to see if the evaporator inside the freezer is frozen or full of ice. Some times you can actually see ice build up on the Pana in the back of your freezer. Is the fan running in the freezer? if there is no ice build and the evap. Fan is working then I would check the compressor and the condenser in the back of the fridge. Are they running? If your freezer is iced up you most likely have a defrost problem and would need to call a service tech. To find out which part is causing it. If the fan in the freezer is bad you might be able to do it yourself. If it's the compressor or condenser motor you would need to call a tech as well.
Have a side by side magic chef the other day I notice the fridge was getting warm and frezzer was starting to ice up in bac took back panel off and took hair dryer to it got rid of ice worked good for...
Should be a passage from the freezer to the fridge with a door way, sometmes a fan, it might not be working.
Or the seal on the freezer side is torn and leaking bad.
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
2helpful
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
I have a Jenn Air refrig JCD 2389GES....the frezzer is working fine, the the fridg is warm.....what should I do? I took the ice maker out and cleaned the slots behind it....the fridg side is still not...
Check the circulation fan in the freezer compartment that circulates the cold to the fresh food compartment. If its not running, and no ice is on it to bind uo the blades, replace the motor.
Kenmore fridge
First we need to see if the compressor is running.  Pull the fridge out take off the lower panel on the back and see if you can hear it running.  Also, need to know if freezer fan and fan by compressor is running.  Check for thick frost build up on back panel in freezer.  Let me know what you find.
1helpful
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Top Admiral Refrigerators Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
